Old 01-20-09, 02:27 PM   #1
SVOboy
SVOboy's Avatar
Default Fridge curtain to keep the air from falling out?
I'm kind of interested in this. Anyone done it? What kind of plastic would you use,
Old 01-20-09, 05:07 PM   #2
Tony Raine
haven't done it, but intrigued. what about those thick strips of plastic for workshop doorways?
Tony Raine is offline   Reply With Quote
Old 01-20-09, 06:56 PM   #3
james
I always thought about doing this. Haven't though because we dont have a fridge.
Thats why chest freezers are so efficient, no air falls out when you open the door. Have you guys seen the kits for sale that converts the thermostat on a chest freezer to operate as a fridge...it uses less than 1/3 the energy of a regular fridge.
james is offline   Reply With Quote
Old 01-20-09, 07:50 PM   #4
MetroMPG
Infrequent noob
I'd think any plastic would work - clear makes sense, of course.
If you own the fridge, you could make a top hatch, or put a hatch in the door.
Or, just lay the thing down on its back. I think Trebuchet did that.
Old 01-21-09, 02:28 AM   #5
SVOboy
SVOboy's Avatar
James -
Do you have a link? I'd be interested to see that.
Old 01-21-09, 08:54 AM   #6
james
It is simple, all you do is put an external thermostat on it with a temp probe that goes into the freezer. Apparently they only run several minutes per hour and are much quieter than a reg. fridge. One problem is that it is much harder to organize and get to things in it.
Go to this site, and go to refrigeration.
Backwoods Solar Electric Systems
I think there was a guy in australia who also did this. would have to search for the link.
Old 01-21-09, 08:57 AM   #7
james
one super simple mod would be to raise the front of the fridge up a bit, so less air would fall out and the door would seal tightly.
Old 04-11-09, 11:08 PM   #8
roflwaffle
Or industrial freezers. Grocery stores have 'em. The local wallyworld has clear vinyl in a few different thicknesses would be cheap, like fifty cents or so, and should work o.k.
roflwaffle is offline   Reply With Quote
