Old 12-28-20, 06:50 PM   #10
solarhotairpanels
Originally Posted by SimpleManLance View Post
I just checked out both your systems. very cool! On your drain back system, don't you need some sort of a vacuum break to get the water to drain back into the 6 gallon tank?
I forgot to mention that I went up on the roof and installed a vacum break type valve at the highest point where hot water leaves collectors on route back to drain back tank. This valve allows a pinch of air into piping as water flows by but will not allow water to leak out. Just perfect for the application.
Pat from Warwick, RI
Please Note:
Comments and/or suggestions I make here at the forums on 'your' projects as well as my own have all been carefully and scientifically calculated by 'the seat of my pants'
hot air collector
