Old 04-05-10, 06:53 PM   #11
Good to see you back Chaaru. Now that summer is coming, you are going to need that system running soon.
Got my Sanyo replacement unit at last and have it running. So far, it's doing well.
Looking forward to more of your posts.
Cheers,
Rich
Old 06-22-10, 04:48 PM   #12
TMilazzo
50's Redwood in SC
Question LG Mini-split, Final Stages
Your post about the LG install was a God Send. The LG manual I have does not have any of the neat diagrams you posted. Where did you get the detailed manual you posted?
I am in the process of doing the nitrogen pressure test, and I left the service lines disconnected at the evaporator end to blow out any possible stuff in the lines. I hooked my manifold set to the gas service valve and the liguid service valve. Lines are connected at the condenser end. Did not touch position of service valves, both of which have shrader valves and both service lines have fittings which will depress the shrader stem. When I feed nitrogen, it flows into the liquid line ( and comes out of the disconnected ends) but then nothing will enter the gas lines. I really want to purge the gas lines. Any ideas?
Thanks
Tom
TMilazzo is offline   Reply With Quote
Old 10-17-10, 07:10 PM   #13
Chaaru
Thought I would come back to update my thread....
Here are some pictures of the tools and equipment I had bought for this project
Vacuum pump
Nitrogen regulator
Vacuum Pump Oil
Nylog Blue
Vacuum Gauge
Condensate drain pipe
Branch Disconnect
Chaaru is offline   Reply With Quote
Old 10-17-10, 07:16 PM   #14
Chaaru
Riser Blocks
R-410 Adapter
HVAC Manifold Guage
Condensate Pump
Old 10-17-10, 10:19 PM   #15
Default familiar!!
Wow!! That equipment looks a little familiar!!
Hook up that manifold, micron gauge and vacuum out the hoses.
I'm wondering how well your hose shut-off valves work.
At high vacuum, mine leaked a tiny bit of air inside, whenever they were operated. (closed).
I think the loss was on the pump side, since that's where the micron gauge
was installed. (which showed the loss).
When the valve was shut, the LCD read-out jumped up a bit,
and then when right down, as the pump was still running.
Old 10-18-10, 06:26 PM   #16
Chaaru
Yep, you have been my Guru thru my successful install and we had put our setup to good use this past summer.
Everything went as planned. I will post more pictures shortly.
Yep, my readings jumped as well during operation (closing the valves once pump couldn't bring the pressure down any more) which prompted me to do this a couple of times before releasing the R-410A. Your thread was what had inspired me to take on this project and I am glad I completed it without too much trouble.
The Following User Says Thank You to Chaaru For This Useful Post:
Xringer (10-18-10)
Old 10-18-10, 07:40 PM   #17
Congratulations! That's great! I hope it works out for you..
Can't wait to see all your pics and a review of a 3-zone Mini-Split..
Mine has been working great, heating up the house during these cool fall months.
I hope it's a mild winter, so I can skip burning any oil at all.. (Just 1/2 gal a day for hot water).
I sealed the little snow roof to the side of my house, so I should get less rain (and snow) dripping
down in back of my outdoor unit. I hate that ice buildup..
I've noticed my Sanyo still has the same old over-revving problem that it used to have.
So, we are being careful not to call for more than 2 degrees of heat at a time..
So, do you have a power use monitor set up yet? So you can brag about
your low heating cost??
We are still amazed that our electric bill is so low.
Some months it's even lower than it used to be, before we installed the Sanyo.
I hope our electric rate stays the same for a few more years..
Based on using less heating oil, the Sanyo is well on it's way to paying for itself.
Cheers,
Rich
Old 10-18-10, 07:56 PM   #18
I've had the same experience with mine.
Old 10-18-10, 08:30 PM   #19
It's certainly strange, that we can heat two bedrooms,
living room, dining area/kitchen, bathroom, hallway and the 18'x16' add-on TV den.. Using so little power..
We have been using the Sanyo about every day this month. So far, it's been costing us about 55 cents a day..
That's about 1/3 the cost of the half gallon of oil we burn each day to make hot-water for washing & bathing.
I want my next Sanyo to have a hot-water heater built in!!
Old 11-23-10, 12:02 PM   #20
TMilazzo
50's Redwood in SC
Finished a 3-zone LG mini-split heat pump install late summer. Had some problems (caused by me)which I will share with my next post. Overall, very pleased with performance. Does anyone know where to get a service manual for the LG mini-split? I am more-familiar with Goodman, and they supply excellent manuals, with great troubleshooting guides. The LG manual is marginal in that regard.
diy, ductless, heat pump, mini-split
