Old 12-06-14, 07:22 PM   #1
lt190b
Default Digital Thermometer
Shop General Tools & Instruments Digital Temperature Meter at Lowes.com
What do you all think? I'm not sure why the link doesn't work. Its a General Tools Digital Temperature Meter Item #: 70739 Model #: IRT207
$19.98
lt190b is offline   Reply With Quote
Old 12-07-14, 12:32 AM   #2
RobbMeeX
Eco OWNER!!
Remove http.
Seems like a good product. Good rating. Not as high as I would like but 600°f is plenty for most stuff.
In it for the money (savings)
Old 12-07-14, 03:02 AM   #3
Originally Posted by lt190b View Post
http://http://www.lowes.com/ProductD...ductId=3136869 What do you all think? I'm not sure why the link doesn't work. Its a General Tools Digital Temperature Meter Item #: 70739 Model #: IRT207
$19.98
I looked at the product. The specs seem OK for the price.
I have worked with a Sensiron SHT-15 temperature/humidity measurement chip.
I bought a thing called "Mold Alert", which is really accurate, it may have the SHT-15 inside.
I also built an Arduino temp/humidity measurement hack device, which uses the Sensiron SHT-15 and both of the devices pretty much track temp and humidity like they were twins.
If you breathe on one of them, it drifts off, but otherwise, I am amazed.
Old 12-07-14, 06:50 AM   #4
hamsterpower
Code:
http://  http://www.lowes.com/ProductD...ductId=3136869
Only one http:// needed.
Old 12-07-14, 10:46 AM   #5
I tried this URL, and it's not working for me...
Old 12-07-14, 11:09 AM   #6
Try this:
At first glance, this looks very similar to the black & decker one I won from here last year. I love the thing!
Worth every penny for measuring surface temperatures and hunting down thermal leaks and a hundred other tasks. This model has a higher top end than mine, which is good for measuring exhaust temperatures and such.
Not quite the same as a thermal imaging (FLIR) camera, but just as useful in the right hands. Of course, for hundreds more dollars, you get a better picture.
Old 12-07-14, 11:27 AM   #7
...At first glance, this looks very similar to the black & decker one I won from here last year. I love the thing!...
I have units similar, and they are very, very useful in understanding the nature of heat.
Only thing better is a thermal imager, I suppose.
But in truth, each device, an accurate stationary thermometer, an IR non-contact thermometer and a thermal imager each has a particular niche that it occupies.
Old 12-07-14, 11:28 AM   #8
lt190b
Try this:
jeff, thanks for the correct link. I tried to fix the one in my post but don't seem to be able to. Thanks for all comments, sorry for the bad link lt190b
Old 12-10-14, 05:16 PM   #9
FLIR has its place great for a real outdoors man / military. Not a feasible tool for most homeowners do to its $ costs and limited advantage over a IR thermometer for checking for simple cold spots.
I have a similar model of that IR thermometer that I use fairly often ,and not just for seeking out cold spots from drafts or insulation testing (which it works great for) but also to check for abnormal heat build up in mechanical and electrical devices.
Old 12-10-14, 05:42 PM   #10
lt190b
Thanks Daox
