Old 09-15-15, 01:42 PM   #31
dablack
I can't tell you the model of the camera. It is usually locked up at work. Some of the things I found were just little problems and would have most likely been fixed when I put on the exterior foam. One of two of the problems I found was the equivalent to having a window cracked or a really leaky door. The worst one, I could feel HOT AIR blowing into the house! It was crazy. I was shocked at what I found. Never would have found those trouble spots without the camera.
One of my doors was leaking under the sill! A little spray foam made a huge difference.
Almost every problem was due to lumber on lumber air leaks. I know a sill seal would have helped on the first floor but I thought of it too late. I had plenty of time on the 2nd floor but didn't even think of a sill seal up there! I wish I would have used it between the floor trusses and top of the walls too. Oh well. I'm finding everything bit by bit. It WILL BE a tight house!
Maybe someone can use my pictures to help them when they build.
Austin
dablack is offline   Reply With Quote
The Following User Says Thank You to dablack For This Useful Post:
Daox (09-16-15)
Old 09-16-15, 09:21 AM   #32
Thanks for sharing your findings and fixes!
