Old 04-09-11, 07:55 PM   #1
AirSepTech
Send a message via Yahoo to AirSepTech
Default Marine design HP
Anyone thought of modding one of these for home use? First time I've seen this.
MARINE AIR CONDITIONER WEBASTO FCF 16000 R410A 115/230V | eBay
I couldn't find an installation/tech manual for pump requirments, efficiancy, etc.
Not exactly cheap, but should be easy. I have been looking for basement heat, maybe hack a window unit, 1K gal. solar drainback tank in ground. Found a 20k btu R22 unit for $600 new. But I never have enough hacktime!
But something like this is almost ready-to-go.
AirSepTech is offline   Reply With Quote
Old 04-10-11, 03:29 PM   #2
If you track back in the manifesto thread, there's a link to a company that sells similiar product, but non-marine. The "marine" part puts a premium on it that is not needed for home use. I believe I commented on it being a good source of HVAC supplies.
If your hack-time is limited, you'd be better off getting a mini-split to heat your basement.
The installation time is low and the efficiency is high, and the price you're considering is about equal.
Xringer has a good thread on the procedure.
Regards,
Old 04-10-11, 06:13 PM   #3
mejunkhound
I picked up an old window unit off a 'free pile' on the curb last year that had a bb gun hole in the condensor, was able to hack it into a HP only unit using propane vs R22 (added a TXV off ebay vs the capillary tube), and works OK as a 1/2T equivalent unit out in the barn to just keep the chill off. Total cost about 50 cents worth of propane and $15 worth of brazing rod and Cu tubing.
Old 04-10-11, 07:48 PM   #4
You could get a window unit (wall shaker)with heat pump & heating element (for below 39F)..
Amana AH093E35AXAA 9200 BTU Air Conditioner Heat Pump - eBay (item 390292223049 end time Apr-25-11 12:49:31 PDT)
But, like AC_Hacker said, a mini-split should do the trick. The big plus is low power consumption.
Old 04-14-11, 12:45 PM   #5
Default Congratulations!
Congratulations! This is the kind of success story that I really like to hear... taking a free piece of junk and with some gumption, knowledge and tools, converting that junk into high-efficiency (I consider any COP over 1 to be high efficiency) equipment.
Did you repair the old condenser, or did you substitute/fabricate another one?
How did you deal with the AC cooling control, so it would act as a heating control?
Do you have photos of the tools you used to do the job?
Best Regards,
