Old 10-16-18, 02:13 AM   #16
meelis11
Originally Posted by scion19801 View Post
Step One – Use the above Air Changes per Hour Table to identify the required air changes needed for the use of the room. Let’s say it’s a conference room requiring 10 air changes per hour.
Step Two - Calculate the volume of the room (L’xW’xH’).
Step Three - Multiply the volume of the room by the required room air changes.
Step Four Divide the answer by 60 minutes per Hour to find the required room CFM
i get 192 cfm. that seems aweful high.
another one i found said i needed 12 cfm. so i'm kinda stuck on how big to size my unit.
Why you would select it as conference room if it is your house? I home you dont need more than one air change per hour - and that is boostmode. Normal everyday mode is 0.5-0.3 airchanges per hour.
meelis11 is offline   Reply With Quote
erv, heat recovery, hrv
