Old 05-17-20, 09:37 PM   #1
nokiasixteth
Default Circuit board replacement parts (from mini-split)
Does any one know where to order replacement parts for these things . I had a grasshopper get on my outdoor circuit board some howand fry itself . Now it feels like i am going to fry as summer keeps coming down in the south . Any one that knows where to find replacement parts this would be awesome . I have the air con blue wave series 2 ton mini split . The first 1 ton i bought years ago is still chugging along
ID:	8981   Click image for larger version
nokiasixteth is offline   Reply With Quote
Old 05-19-20, 10:56 PM   #2
NiHaoMike
NiHaoMike's Avatar
Try cleaning up the burned spot and bridging the burned track. If it then works, conformal coat it to guard against further arc flash events.
Old 06-23-20, 07:52 PM   #3
nokiasixteth
You happen to have any recomendations on what type solder to use. I have not got the faintest clue where to start
Old 06-24-20, 08:49 AM   #4
NiHaoMike
NiHaoMike's Avatar
Go with good quality (e.g. Kester) 63/37 leaded solder. Lead free is harder to work with so I do not recommend it for a beginner. For the iron, go for the TS100 if you want one that's portable or a T12 if you want a budget option.
Practice a bit on a scrap board, but it looks like a pretty easy soldering job.
nokiasixteth (07-02-20)
Old 07-21-20, 11:01 PM   #5
nokiasixteth
https://www.ebay.com/itm/2in1-862D-S...53.m1438.l2649
Think a hot gun and soldering iron would come in handy for desoldering things in combination with the soldering iron. Or is that a garbage unit combo . Really not many reviews on youtube i seen as a quick search.
I did find the Ksger t12 . I assumed that was one you had recomended .
https://www.ebay.com/itm/KSGER-T12-M...53.m2763.l2649
Old 05-20-20, 07:18 PM   #6
Here's the web page for your unit:
http://airconint.com/wiki/index.php?title=Blue_Series_3
It looks like the power feed for the outdoor fan motor got burnt. I would definitely check the resistance between the two terminals on the motor connector before I did a board repair. The service manual for your model should have some typical values for reference.
Also, how old is the unit? It may still have warranty coverage. If so, you should be able to send the pics to the manufacturer and get a new circuit board. I'd definitely verify that it's out of warranty before attempting a board level repair.
nokiasixteth (05-23-20)
Old 06-23-20, 07:50 PM   #7
nokiasixteth
Its like a year old . But i installed my self. The guys who are on the page are absolutely not a lick of help . Only pc board i have found was around 350. THinking its time to youtube and figure out how to replace parts on that board . Thats lot higher than i want to spend.
Old 07-10-20, 01:30 AM   #8
WyrTwister
$ 350 is about what the motherboard of our mini split cost . Ordered it from the supply house I purchased the mini split from .
I took the old one out , installed the new one . Took the old one back to the supply house I purchased the mini split from and the refunded my money . Less than 1 year old & under warranty .
God bless
Wyr
Old 05-23-20, 11:59 AM   #9
nokiasixteth
It is about 1 yr or so old . It is possible . I havent even thought about it still being under warranty. That may be a possibility.
Old 06-11-20, 09:42 PM   #10
WyrTwister
We had a brown out during a snow storm , several years ago . Damaged the PC board on our 12,000 BTU Fredrich mini split .
I purchased it locally at a HVAC supply house . They warrantied it for me . :-)
Seems like the board would have cost around $ 350 , if it had not of been under warranty ?
Wyr
God bless
