Old 02-09-15, 01:04 PM   #11
ecomodded
I really like the idea of burning waste oil for heat , once you find your supply your set.
A high pressure fluid transfer pump could be used to siphon and inject the fuel out of the nozzle , to reduce maintenance cycles you could use multiple nozzles , which in effect would reduce the flow rate past each nozzle.
I am thinking a pump would need more grunt then pressure , 25 psi *might* be enough pressure to spray the thicker oil adequately.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
