Old 11-14-14, 12:41 PM   #1
Wkmaylish
Default Gree multi mini split install
I am about to finish an install of a Gree Multi+ Dual-Zone unit and have a question.
I am currently at the leak test and vacuum portion of the install. The instruction state
“Leak test each indoor unit, one unit at a time. Repeat the leak test sequence for each indoor unit.”
And
“Evacuate each indoor unit, one unit at a time. Repeat the evacuation sequence for each indoor unit.”
My condenser is capable of 4 indoor units but only has one set of service ports.
Are the instructions generic or is there a way to do each individually?
Wkmaylish is offline   Reply With Quote
Old 11-14-14, 08:35 PM   #2
Which model. They are different
Old 11-15-14, 07:45 AM   #3
Wkmaylish
Default Model
From the website:
Gree Multi+ Dual-Zone Ductless Mini-Split System 36,000 BTU Inverter Heat Pump (18k, 18k Indoor)
BRAND: Gree SKU: MULTI36HP205
NEW MODEL – Replaces Evo+ Multi – Bu
Old 11-15-14, 08:15 AM   #4
Open up the outside electrical box. Do you have electrical inputs for more than one indoor unit? If not, it looks like you may have the wrong outdoor unit.
Old 11-16-14, 03:27 PM   #5
Default Pictures speak novels
No extra plumbing required ( LINESETS ALONE WILL WORK)
Single zone unit:
Four zone unit:
Cousin brand multi zone units:
Extra plumbing required:
ZONE SPLITTER SET: Fujitsu part no. UTP-SX248A $159
BRANCH BOX:
Daikin part no. BPMKS048A2U $799
Fujitsu part no. UTP-PU03A is cheaper at (only) $399
Impossible in reality, but not in photoshop:
Old 11-17-14, 07:04 AM   #6
Wkmaylish
Sorry for the delay in responding.
I have a condenser similar to the one shown in the jeff5may's post. It can handle up to four units, 4 sets of high/low ports labeled A-D. It also has another set of high/low ports with the service port.
My question is, How can you pressure test and vacuum each indoor unit separately if you only have one service port?
I may be explaining this wrong so I hope to take some pictures tonight and post them for further clarification.
Old 11-18-14, 10:21 AM   #7
Wkmaylish
Default Pics
Here is an image.
You will see that I have 4 connections and a set of service ports(High/low)
Sorry for the dark picture, I leave for work in the dark and get home in the dark.
Old 11-18-14, 10:21 AM   #8
Wkmaylish
Actually here is the picture:
Old 11-19-14, 05:36 PM   #9
Xringer has graciously answered this question before:
http://ecorenovator.org/forum/5575-post4.html
Many of us have been down this road before. The thread I cited will give you a general idea of the job that lies ahead of you. If you don't have the specialty tools needed for this install, buy, beg or borrow them. They will make the job SO much easier and ensure that the system will be reliable for a much longer time than they are worth. This is one of those cases where the $30 flare nut wrench and the $100 micron gage are worth every penny.
Good luck and please post lots of pics!
gree, mini split, pressure test, vacuum
