Old 02-13-15, 12:50 PM   #1
buffalobillpatrick
Default Arduino PID Relay Temperature Control
I stole this:
Code:
 * Arduino PID Relay Output Example
 * The output is going to digital pin 6 which is controlling
 * a relay.
 * The current temperature is read via pin A0
 * The pid Library is designed to only output an analog value,
 * but the relay can only be On/Off.
 * To connect them together we use "time proportioning control"
 * It's a really a long duration version of Pulse Width Modulation (PWM).
 * First we decide on a window size (5000mS say.)
 * We then set the pid to adjust its output between 0 and that window size.
 * Lastly, we add some logic that translates the PID
 * output into "Relay On Time" with the remainder of the
 * window being "Relay Off Time"
#include <PID_v1.h>
#define RelayPin 6    //D6
#define T_pin   A0    //A0
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Define the Tuning Parameters
double Kp=2, Ki=5, Kd=1;
//Specify the PID links
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
int WindowSize = 5000;          //5 sec
unsigned long windowStartTime;
void setup()
  windowStartTime = millis();    //get current time
  Setpoint = 100;                //Desired Temperature
  //tell the PID to range between 0 and the full window size
  myPID.SetOutputLimits(0, WindowSize);
  //turn the PID on
  myPID.SetMode(AUTOMATIC);
void loop()
  Input = analogRead(T_pin);  //Pass current temperature as Input to PID
  myPID.Compute();
  unsigned long now = millis();  //get now time
  if(now - windowStartTime > WindowSize)
  { //time to shift the Relay Window
    windowStartTime += WindowSize;
  if(Output > now - windowStartTime) digitalWrite(RelayPin,HIGH);   //ON
  else digitalWrite(RelayPin,LOW);                                  //OFF
