Old 12-18-13, 06:28 AM   #1
Servicetech
Servicetech's Avatar
Default Gas meter "Constant" charge
Can anybody tell me what the 1.0920 "constant" charge is?
Old 12-18-13, 06:50 AM   #2
Can you elaborate on the bill? Actually the best way is to call the gas company and ask them.
Old 12-19-13, 06:29 AM   #3
I imagine it is:
A. How much your meter reading is off from actual usage
or
B. How much gas leaks out of the lines before it gets to the meter
Old 12-19-13, 08:17 AM   #4
iamgeo
Constant – The Constant is a pressure factor or meter factor used to convert metered volume to bill volume.
Taken from.....
https://www.oklahomanaturalgas.com/C...gYourBill.aspx
Old 12-19-13, 05:40 PM   #5
Servicetech
Taken from.....
I saw that, just don't understand what it means.
Old 12-19-13, 06:30 PM   #6
It means guess A.
Old 12-26-13, 07:52 AM   #7
gasstingy
If it doesn't mean any of that, perhaps it is what I'd call a Base Charge. In other words, for the privilege of having their service connected to your house and for them pay the meter readers, accounting staff and mail, etc, they have to charge a certain minimal amount whether you use it or not. In my area, as best I can figure out {using my mothers summer billing}, we pay just less that $8.00/mo as a Base Charge.
FWIW, jeff5may has two choices that seem more likely.
Old 12-26-13, 08:16 AM   #8
iamgeo
It's been over a week since you posted. I'm sure by now you have called the company and they told you what the "Constant" is for.
Please enlighten us.
Old 12-26-13, 08:21 AM   #9
Servicetech
Haven't called in yet. I'll post once I know for sure.
Old 12-26-13, 02:34 PM   #10
Servicetech
Called the gas company and the CSR wasn't certain. The best she could come up with is ONG delivers the gas at a slightly higher pressure than the meter is calibrated for, therefore the meter is "slow". It does align with my findings when I clock my furnace/water heater/etc.
The Following User Says Thank You to Servicetech For This Useful Post:
gasstingy (12-26-13)
