Old 12-15-12, 04:40 PM   #221
I've looked at a few MPPT parts on the web and have not seen many items that looked like they would be very easy get working.
Too many small parts add to the complexity and cost.
For a 26AH battery, it seems like a 60W PV panel would be more than power to do the job, using a regular charger circuit.
If that's not enough, I would most likely just buy a cheap Chinese MPPT charge controller.
10A MPPT Solar Regulator Charge Controller 12V 24V Autoswitch Solar Panel | eBay
I don't think that I could build a DIY for under $20 USD..
Aliexpress.com : Buy 10A MPPT Solar Regulator Charge Controller 12V 24V Autoswitch Solar Panel free shipping, wholesale, #160122 from Reliable Solar Regulator suppliers on seller best's store
Old 04-25-13, 11:56 AM   #222
giorgioart
Default solar tracker
Salut Dane
Eu sunt Gigi, am intrat aici tot pentru un tracker solar, adica pentru un circuit...eu sunt afon in electronica dar mare fan al concentratoarelor solare, am intrat si deschis subiecte pe tema asta pe diferite forumuri de la noi, si am dat de multi talibani..in fine, daca esti dragut..sa-mi zici si mie daca ai facut circuitul asta de la MTM si daca este ok. Multumesc anticipat
Gigi
adresa e-mail....gigi_gavrila2002@yahoo.com
giorgioart is offline   Reply With Quote
Old 04-25-13, 02:29 PM   #223
Originally Posted by giorgioart View Post
Salut Dane
Gigi
rough translation:
Hi Dane I am Gigi, I came here all for solar tracker, ie for a circuit in electronics ... I'm dumb but big fan of solar concentrators, I went and opened topics on various forums about this from us, and I gave many Taliban .. however, if you're nice to me .. if you did say to me that the MTM circuit and if it is ok. Thanks in advance Gigi e-mail .... gigi_gavrila2002@yahoo.com
Daox (04-25-13), giorgioart (04-25-13)
Old 04-28-13, 10:50 AM   #224
The MTM tracker uses relays. If the motor current is high (mine was only a couple of amps at 12V),
the relays will slowly wear out.
It might take a long time with light power loading or, the relays might fail in one summer.
The RedRock tracker will last longer, since it uses transistors, instead of relays.
Old 06-16-13, 05:28 AM   #225
michael.skov
Default need the diagram for the tracker
Hi
I am in the process of building my solar tracker and appeared to the tracker you bought looks reasonable and simple out so I will ask if you still have the papers from the (diagram and the other stuff) and if you want to send copies to me
thanks in advance
michael.skov @ mail.dk
michael.skov is offline   Reply With Quote
Old 06-16-13, 08:16 AM   #226
LED3X Solar Tracker Assembly
I love my RedRock tracker. This one has been working great for a couple of years now.
That MTM board with the relays couldn't even last a summer. Plus, the photo sensors included were too sensitive to heat.
Not a good characteristic for a device you are going to leave out in direct sun light.
But, MTM has a new model now.. Solar Tracker Circuit Kit
with more features, but it still uses the old relay tech, instead of power MOSFETs.
Either type of MTM board might be good for a solar demonstration setup.
Where it wasn't required to run a tracker motor 365 days a year.
Old 06-16-13, 11:34 AM   #227
michael.skov
Default the mtm tracker
it whos the mtm tracker whit relay i whos interested in
do you still have the paper om that
regards
Old 06-16-13, 03:47 PM   #228
MTM keeps their circuit diagrams secret.
I think they want to people to buy their product, instead of copying it.
If you really want to use relays, there are simple circuits posted on the web..
Electronic Projects
"This is about the simplest tracker I know of. It uses a Radio Shack 275-249A relay. Adjust the sensitivity of the CdS cells with a Sharpie permanent marker as described bellow, in the Chace tracker. The picture tells it all.
This tracker is not as accurate as the electronic tracker but quite sufficient for use with PV panels.
While the proof of concept is good it will burn the relay contacts. This is caused by the relays being turned on or off slowly. It melted the plastic case on the relays. "
edit:
Schematic for Solar Collector Sun Tracking, Richard Gideon shares solar technology, Phoenix Turbine Builders Club Developer of the Month
Here's another relay tracker for those who fear the transistor..
This one looks pretty good. If you build one of these, be sure to use socket-type relays, so you can replace them when they die..
Old 06-16-13, 04:02 PM   #229
Just looked for Solar trackers on Ebay and it's nice to see there are products similar
to the RedRock starting to show up..
Category 1 items in Richardsfoundry store on eBay!
Wow this can do 10A at 12Vdc?? That's 120 watts of motor drive!
If my RedRock gets zapped, I know where my next tracker board is coming from!
Old 06-16-13, 04:43 PM   #230
michael.skov
Default the mtm 1 more time
please if you have the tracker wil you atlest take a Picture of the bagside of it wher your solder the component i have a Picture of the component side
bur need the underside
so please please please
regards
Michael Skov
electric, solar, tracker
