12-02-11, 08:10 AM | #201 |
Dan_LASER
thanks for advice
but will ask something u can do 2 pics with the circuit? one front and one back? so I can see track circuit so I can make myself one like that please |
12-02-11, 08:15 AM | #202 |
Dan_LASER
i dont have money now
to buy a circuit my wife is pregnant and all money goes to her need to take care of her and the baby and so we spent too much money on panels and batteries |
12-02-11, 08:55 AM | #203 |
Just Google MTM Tracker..
Here's what I found online.. solar tracker mod http://www.demiurgiac.com/MTM%20schematic.jpg
The Following User Says Thank You to Xringer For This Useful Post: | giorgioart (04-25-13) |
12-02-11, 09:20 AM | #204 |
Dan_LASER
thank you
12-31-11, 03:34 AM | #205 |
Dan_LASER
dear sir XRINGER
Thanks for the scheme I built two pieces of solar traking works but I have a little problem How do I connect switches of acttuator If you do not mind to help me with this problem thank you |
12-31-11, 10:04 AM | #206 |
Limit switches are installed to open the motor current flow,
when the mount reaches End-of-travel. LED3X Solar Tracker Assembly Diodes are installed across the switches contacts, so that reverse is possible, after the month hits End-of-travel. I used a satellite dish mover actuator unit, because it has build-in limit switches. I had to buy a new model with 'limits', since my old unit didn't have switches.
05-22-12, 11:11 PM | #207 |
Hi Xringer!
I read this thread and am curious if you are going to do more than resistance heating with the electricity after sorting out the mount. Have you thought of adding serpentine cooling loops to the backside of PV panels? If you did this, you would get cooler panels (boosting efficiency), a high percentage of the total solar energy as the heat you are looking for now, and you would still keep the hard won "high energy content" electricity for DC uses or inverters. BTW-as you know, that Occam (Ockham) guy is on to something! Craig
"I‘d put my money on the sun and solar energy. What a source of power! I hope we don‘t have to wait until oil and coal run out before we tackle that." Thomas Edison, 1847 — 1931 |
05-22-12, 11:16 PM | #208 |
Maybe your wife would like the panels on the roof if you intergrate some Sanyo HIT doublesided panels into a new portico
05-23-12, 06:25 AM | #209 |
The tracker PV is connected to my back-up battery bank. 500w is over-kill for the bank,
so I've disconnected the actuator motor on the tracker. The solar part of the back-up system (to power sump pumps) was basically an experiment that worked. But, maybe I should have just used a 48v battery charger, with a 120vac wall plug.. (At least until we hit we hit Peak coal in 2025).. I am getting pretty good use out of my 800w fixed mount PV. It's heating my hot water storage.. I'm now starting to think, the best use of PV is grid-tie.
My hobby is installing & trying to repair mini-splits EPA 608 Type 1 Technician Certification ~ 5 lbs or less.. Last edited by Xringer; 05-23-12 at 06:44 AM.. |
05-31-12, 11:45 AM | #210 | |
I find most of my parts on Ebay. Those that come from China get here slow. 3 weeks is typical. US shippers average 1 week.
Tags |
electric, solar, tracker |
