Old 09-24-14, 10:37 PM   #461
gtojohn
gtojohn's Avatar
I use one of these when it comes time to quantify airflow and changes. I does require some averaging.
http://www.amazon.com/General-Tools-...ords=meter+fpm
One of the biggest difficulties for diy systems would be btu measurement. I see variations in manufacturer's btu certifications on systems' output with the same condensing unit and different blower or coil options. Without the correct btu output you can't calculate seer or btu per watt.
Old 05-15-15, 09:08 AM   #462
kostas
Default My DIY HRV system completed
Hi people, it's been a while since my last post, after many months of hard work I finished what I call the first version of my complete DIY HRV home system. As I previously said I wanted full-house ducting with outtakes in the livingroom and bedrooms and intakes in the bathrooms and kitchen. That meant lowering 13cm the whole ceiling of the first floor, some 45sqm of drywall done in aprox 10 days work there... By the way I also installed new recessed LED lighting and an also recessed VPR motorized housing with motorized screen and HT sound system. I finished the first floor last August (2014) and the rest of the ducting by February of this year. The HRV is rocking since then and, even if the winter wasn't very cold this year, the inside comfort is superb! No more window opening, no more cooking odors on the second floor, no more steamy mirror while taking showers! Last but definitely not least, you get all that fresh air during the sleep, which is priceless.
Here are some photos:
First floor plan with duct project (orange return, blue supply)
Kitchen return boots - project
Boot construction:
Distribution plenums:
Demolition man!
Left: corridor supply hole, right: kitchen return and livingroom supply hole.
Twin boot (kitchen return and livingroom supply) project and construction
>>>continues to next post>>>
Name:	SCHEMA PIANO 1.jpg
ID:	5274   Click image for larger version
Name:	aspirazione cucina con tubi.jpg
ID:	5278   Click image for larger version
Name:	plenum aspirazione cucina 2.jpg
ID:	5279   Click image for larger version
ID:	5280   Click image for larger version
ID:	5282   Click image for larger version
ID:	5283   Click image for larger version
ID:	5284   Click image for larger version
Name:	passaggio sogg parte sotto2.jpg
ID:	5285   Click image for larger version
The Following 3 Users Say Thank You to kostas For This Useful Post:
Daox (05-15-15), ferox (03-09-16), Piwoslaw (05-15-15)
Old 05-15-15, 09:23 AM   #463
kostas
<<<continued from previous post<<<
Twin plenum installed:
Kitchen boots installed:
Corridor duct:
Corridor duct installed on the left, VPR recessed motorized lift (DIY, of course!) and twin boot on the right, Santorini in the center :
Kitchen return ductwork:
Distribution plenums and drywall construction:
Cladding finished, this is the kitchen return hood:
And this is a finished view with the new lighting fixtures:
ID:	5287   Click image for larger version
ID:	5288   Click image for larger version
ID:	5289   Click image for larger version
ID:	5290   Click image for larger version
ID:	5292   Click image for larger version
ID:	5293   Click image for larger version
ID:	5294   Click image for larger version
ID:	5295   Click image for larger version
Daox (05-15-15), ferox (03-09-16), MADIFI (02-06-22)
Old 05-15-15, 09:38 AM   #464
kostas
Grilles and filters:
Livingroom grille:
Corridor supply and mixing grille:
Bathroom drywall cladding:
Bathroom return stackhead:
Stackhead installed with grille:
ID:	5297   Click image for larger version
ID:	5298   Click image for larger version
ID:	5299   Click image for larger version
ID:	5300   Click image for larger version
ID:	5302   Click image for larger version
ID:	5303   Click image for larger version
ID:	5304   Click image for larger version
ID:	5305   Click image for larger version
Old 05-15-15, 09:51 AM   #465
kostas
Over the stairs return grille:
2nd bathroom return grille while checking air speed:
Kids bedroom supply grille:
Bedroom supply grille:
Supply and return chimneys construction (you can see the IKEA bowls I used as caps)
Roof installation:
Inside ductwork to the HRV (from bathroom and kitchen and to livingroom)
Bathrooms return plenum with spiraled tube attached to the HRV:
Name:	asp scale 1.jpg
ID:	5307   Click image for larger version
ID:	5308   Click image for larger version
Name:	imm cameretta.jpg
ID:	5309   Click image for larger version
Name:	imm camera.bmp.jpg
ID:	5310   Click image for larger version
ID:	5312   Click image for larger version
ID:	5313   Click image for larger version
ID:	5314   Click image for larger version
ID:	5315   Click image for larger version
The Following 2 Users Say Thank You to kostas For This Useful Post:
Old 05-15-15, 09:59 AM   #466
kostas
To the bedrooms PAL ductwork:
The beast is on!
Arduino control board. I used 4 DHT-22 temperature and humidity sensors, one for each flow, and 6 relays for the two motors (3 for each one, one per speed)
Arduino web interface control panel:
DIY ultrasonic humidifier (dedicated post in the near future )
That's all for now, hope you enjoy
ID:	5317   Click image for larger version
ID:	5318   Click image for larger version
ID:	5319   Click image for larger version
ID:	5320   Click image for larger version
The Following 4 Users Say Thank You to kostas For This Useful Post:
BillG (07-21-16), Daox (05-15-15), grba (10-04-15), Piwoslaw (05-15-15)
Old 05-15-15, 10:06 AM   #467
Default What an awesome project!!
Amazing, inspiring project, and beautifully documented too.
Thank you for going to the trouble of posting it for all to see.
I would have to say, that I fear that the small holes you drilled in the outlet covers, might restrict the free flow of air, and may increase noise and energy cost.
Other than that, I am astounded.
kostas (05-15-15)
Old 05-15-15, 10:10 AM   #468
That is very impressive work! It looks great and to hear its functioning well is even better news. Thank you for sharing!
kostas (05-15-15)
Old 05-15-15, 05:03 PM   #469
kostas
Thanks, glad to contribute.
AC, the covers are machined punched, the two small ones are shelves from the local IKEA store and the long one (kitchen) is custom made. There are more than 3200 ø5mm holes in it, which is more than enough for a single inlet. Besides, the whole ductwork is actually oversized as I used ø150mm (or equivalent when rectangular) for almost every branch, which could hold up up to 200 m3/h (118 cfm) within the safe range of laminar speed (that's 3m/sec) and thus virtually noise free. The actual flow of every branch is hardly 25 m3/h for everyday use, so I'm quite sure about having no unwanted turbulence.
AC_Hacker (05-17-15), ferox (03-09-16)
Old 01-12-16, 10:06 AM   #470
tinco
Hi This thread is great. I've been looking at the Recair premade recuperators, they're really cheap. I saw Fornax has posted pictures but they seem to have disappeared, anyone know if they're still around somewhere? I'm a forum newbie so I don't have PM rights yet to ask Fornax for them.
Cheers!
tinco is offline   Reply With Quote
erv, heat recovery, hrv
