Old 06-28-14, 08:19 PM   #61
I was not implying anything other then what the numbers denote ?
Old 06-28-14, 08:26 PM   #62
What ever you do DO NOT ADD INSULATION TO YOUR FRIDGE - I REPEAT DO NOT
You don't want helpful advice - YOU GET NONE ya grumpy mf lol
Old 06-29-14, 01:11 AM   #63
I wish your insights were as useful as you imagine them to be.
Old 06-29-14, 05:58 PM   #64
Please explain. Are you talking about adding insulation to a fridge with coils that would be insulated or are you saying not to add insulation inside the fridge? I'm looking to do the latter because I don't need as much cubic footage, I have the spare insulation, and there's no room for insulation on the top, bottom, or sides unless I put the insulation inside the refrigerator.
Old 06-29-14, 11:05 PM   #65
Please explain. Are you talking about adding insulation to a fridge with coils... etc.
I realize that you are addressing your question to ecomoder, but I think that adding insulation to an existing refrig will result in only marginal improvement.
However if you gave up on your present fridge, and did a Freezerator conversion, your energy use would be cut in half, or even better.
Old 06-30-14, 10:22 AM   #66
I understand what you are saying but if I want both a refrigerator and a freezer in my kitchen without taking up additional space in the kitchen, adding insulation to a fridge/freezer combo unit seems to be the best route to go about it. By putting the insulation inside the fridge, I reduce the volume of air that is lost from when the refrigerator is opened along with being able to reach a higher R value than I otherwise can by putting it all on the outside. Depending on how much spare insulation I have left over I'll be putting some on the back and top as well, I just don't have room on the sides and the design of my fridge doesn't allow for any under the refrigerator.
Old 06-30-14, 11:17 AM   #67
I understand what you are saying but if I want both a refrigerator and a freezer in my kitchen without taking up additional space in the kitchen... I just don't have room on the sides and the design of my fridge doesn't allow for any under the refrigerator.
OK, so on with the project!
Old 06-16-15, 03:57 PM   #68
Default Freezerator Update...
The freezerator keeps chugging along.
It is still condensing frost on a continual basis, so there is no buildup.
Produce that is in the freezerator still lasts surprisingly longer than in conventional refrigerators.
I have purchased a, aluminum food service tray that is as long as the freezerator is wide. The front 'feet' of the freezerator are in the tray, and the rear 'feet' of the freezerator are shimmed to bring the freezerator to just slightly more forward than level. So, occasionally the condensation runs out of the door and into the aluminum tray and evaporates. I never see any build-up.
My Kill-a-Watt looses its memory from time to time, but this morning's reading was over a 90.35 hour run, and the Kill-a-Watt recorded 1.46 kW-h used during that time.
My local electricity rate is $0.11/kW-h.
This calculates to $15.57/per year.
All this from the least energy efficient mini-freezer on the market (previously well used), that was converted to a refrigerator with a $20 part.
Daox (06-16-15)
Old 06-16-15, 04:50 PM   #69
That is very good energy usage.
My 4.5 cu mini refrigerator uses 235 KHh a year and I had to shop around to find one that low.
Old 06-16-15, 06:05 PM   #70
I know what you mean.
The unit I chose was chosen on the basis that I found it on Craig's list, it was cheap, and my girlfriend could help with transportation.
I already knew that the model I chose was at the bottom of the heap, but my intention was to see what the percentage of improvement would be as compared to the a similar unit, designed to be used as a refrigerator.
The results went way beyond my expectations. I imagine that the percentage of improvement would hold for a more efficient mini-freezer, too.
And it would be even better if a chest-type freezer was used, but I know that with my deplorable life-style, many things, heavy things, would accumulate on top of the freezerator lid, and I'd have to deal with them when I was grumpy and hungry.
I'm very happy with the result.
