Go Back   EcoRenovator > Forum News & Feedback
Old 12-15-10, 09:29 AM   #61
SVOboy
SVOboy's Avatar
Yeah, I'm gonna kill that view link now.
Piwo, try editing my test house with the name "piwo edited this"
Curious to see if it'll work now.
Added the ability to upload an image!
Old 12-15-10, 10:01 AM   #62
Piwoslaw
Piwoslaw's Avatar
OK, it looks good. I can go into the editing part, but saving only brings back the values you entered (I wanted to add some solar to your place). Plus I got the Stop editing me! scolding.
When I said earlier that I can edit other homes, I didn't try to save.
Way cool
But when there is no picture yet, the space is taken up by an empty field.
Name:	EcoRenovator Energy Tracker - EcoRenovator_1292428696927.jpg
Old 12-15-10, 12:09 PM   #63
strider3700
When I opened my home to edit it started back to the default values for all of the systems. it should reload the existing saved so that I can only change one or two things about it.
Old 12-15-10, 12:18 PM   #64
strider3700
When I view homes without pictures there is a broken picture link displayed. It probably shouldn't be there.
Old 12-15-10, 12:34 PM   #65
Piwoslaw
Piwoslaw's Avatar
Right. Also, if you enter none in one of the fields, say in cooling, then all the lower fields in cooling should automatically set to none. Or maybe if one of the fields are set to none then the lower fields in that system should disappear. Now, Primary Cooling System can be set to none but the Secondary Cooling System and Tertiary Cooling System can be set to anything.
Oh, and when in Edit mode, the button at the bottom should be "Save Values", not "Edit Home Values".
Old 12-16-10, 02:42 AM   #66
SVOboy
SVOboy's Avatar
Thanks for all the input guys. I'm going to make photos of homes mandatory, so eventually that broken image space won't mean anything. Though in chrome it's really tiny and not obscenely large, so it didn't bother me at first.
Also, working on the editing for systems. I honestly dunno how to fix it, but I'll figure it out.
Old 12-16-10, 02:49 AM   #67
strider3700
oh while you're in there can you add a field for us to save a weatherstation id I use IBCNANAI6 for mine for instance.
Old 01-06-11, 06:37 AM   #68
SVOboy
SVOboy's Avatar
Done today:
Moved to a non-testing page.
Added links to user pages.
Cleaned up page linking.
Hid all the "nones" on individual pages.
To do:
Add links to header.
Old 01-06-11, 06:50 AM   #69
NeilBlanchard
NeilBlanchard's Avatar
My Home is mostly blank. I was going to put in the latest months gas use.
Old 01-13-11, 06:41 AM   #70
NeilBlanchard
The data table on my Home is still blank. I am trying to add some energy use from December.
