Go Back   EcoRenovator > Improvements > EcoRenovator Blog Discussion
Old 09-14-09, 07:43 AM   #1
SVOboy
SVOboy's Avatar
Default DIY Ground Source Heat Pump – Part 5: Welding Plastic
This entry is part 5 of 5 in the series DIY Ground Source Heat PumpIn part 4 of our series, AC Hacker had just found out he could weld plastic without too much trouble. He used a skillet on a stove, heated up two short pieces of tubing, and pushed them together forming what you [...]Post from: EcoRenovator.org
More...
