Old 02-11-16, 11:39 AM   #1
Default Straw bale gardening
In my internet travels I ran across this.
Looks simple enough to try. I did read where someone used hay and introduced weeds so only use good straw.
Here is a PDF that tells you what you need to know.
https://www.fieldmuseum.org/sites/de...ardening_0.pdf
http://cru.cahe.wsu.edu/CEPublicatio...09E/FS109E.pdf
Old 02-12-16, 07:23 PM   #2
MEMPHIS91
MEMPHIS91's Avatar
I did this last year.
I learned a lot.
Used OLD hay bays, at least a year old, the weed/grass seeds will sprout and die and not come back.
Water some barn yard fertilizer in for a couple weeks before you plant.
They tend to attach ants and slugs. So have some corn starch ready to fight the ants off and I put left over copper at the bases to kill any slugs.
They do work. I have cherry tomatoes and green bell peppers do very well last year. Not sure if I took pictures or not. It was during the DX hotwater heater build.
Old 02-12-16, 08:18 PM   #3
This method is perfect for urban gardening. It can be done just about anywhere the weather isn't super harsh. Imagine a square foot garden on a roof, in a wheelbarrow, truck bed, or wagon. There are very few limits as to where or how these powerhouses can be set up. Just when I thought I had seen them all, someone comes up with a new surprise design. They take a little more watering than a dirt garden in most climates, but little to no weeding. At the end of the grow season, the bales can be broken down and spread as compost or mulch. Super kool!
Old 02-12-16, 10:18 PM   #4
MEMPHIS91
I would like to see the pictures if you have them.
Jeff
Nice pictures.
I saw one setup where they took two bales stacked. They did not have to bend over at all. That would probably need even more water.
Old 02-13-16, 12:01 AM   #5
For not huge grows, straw bale plantings go well with rain water collection barrels and drip irrigation. The combination lends itself to really low maintenance. I like the solar rainmaker. It's pretty durable and just works.
The one I bought cost more than they do now. Mine came with batteries, the new ones do not. Big whoop, the thing takes 3 AA rechargeables. I used mine for a season, then gave it to grandma when she showed lots of interest. Like I said, it just keeps working.
