Old 02-09-15, 01:04 PM   #11
ecomodded
I really like the idea of burning waste oil for heat , once you find your supply your set.
A high pressure fluid transfer pump could be used to siphon and inject the fuel out of the nozzle , to reduce maintenance cycles you could use multiple nozzles , which in effect would reduce the flow rate past each nozzle.
I am thinking a pump would need more grunt then pressure , 25 psi *might* be enough pressure to spray the thicker oil adequately.
Old 02-11-15, 08:40 AM   #12
Greg
Yah there are lots of ideas on the net with that preasure principle. I wouldn't mind playing with a babington burner but as I said I have solar and can't have the electrical draw from my batteries to run a compressor. How convienent it would be to have plugs live 24/7 but then u have a bill. I made this work with the stuff I had at hand and it works well on 50% WVO and contaminated jet fuel. Still free heat.
Greg
Greg is offline   Reply With Quote
The Following User Says Thank You to Greg For This Useful Post:
ecomodded (02-11-15)
Old 02-11-15, 10:32 AM   #13
ecomodded
The Jet fuel = kerosene
I used to deliver drums of Jet fuel out to the Bush for our work helicopters , I felt safer knowing it was a Type of kerosene.
I bet it thins the WVO very well.
Old 03-24-16, 08:26 AM   #14
Greg
Check out YouTube 2jeffs1 he has a nice wood stove conversion I kind of copied for mine and it works well.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
