Old 09-19-08, 10:50 PM   #1
SVOboy
SVOboy's Avatar
Default How many watts does a new microwave suck down in standby?
Just measured my crazy old one and it takes 4 watts in standby, wondering what the new ones use up,
Thanks ya'll
Old 09-19-08, 10:51 PM   #2
SVOboy
SVOboy's Avatar
PS: that's about 3 kwh a month from just the microwave!!! Arg.
Old 09-20-08, 01:36 AM   #3
roflwaffle
Maybe 1.5-2 times that.
roflwaffle is offline   Reply With Quote
Old 09-20-08, 01:46 AM   #4
groar
X-Frenchy: very
groar's Avatar
So mine isn't so crazy
From an ecomodder message :
Tested my microwave (~10 years old) :
. idle : 3W
. at max power, 900W given back to food : 1550W
. "idle" after use, waiting for someone to push the stop button, light and turning tray activated : 50W
Denis.
    (2.66 kg/l diesel)
    (59.1 g/kWh)
Old 09-20-08, 02:10 AM   #5
groar
X-Frenchy: very
groar's Avatar
I have a simple rule :
1W continuous = 1€/year = 1.5kg CO2 or 0.2g uranium.
In fact it's 0.88€ (1.27$), 1.4kg CO2 (0.16kg/kWh) and 0.19g uranium (0.022g/kWh) but the little bit more motivates a little bit more to reduce the continuous flow. These are based on the French numbers, US may have much more CO2 are far less uranium.
Denis.
    (2.66 kg/l diesel)
    (59.1 g/kWh)
Old 09-20-08, 05:31 PM   #6
SVOboy
SVOboy's Avatar
Thanks, I'm glad to hear it's not more than current units. I'll have to get my mom to put in on a switch since the clock is pretty redundant anyway,
Old 09-30-08, 01:49 PM   #7
Binger
When we moved into our appt. I went about a week without setting the clock and finaly it just blacked out. So I wonder if this saves more like this. No need for the clock when I can just turn around and look at the one on the stove.
Binger is offline   Reply With Quote
Old 09-30-08, 02:18 PM   #8
I just got my kill-a-watt back Sunday night. I'll check out my microwave tonight.
Old 10-02-08, 08:48 AM   #9
bennelson
Home-Wrecker
On a related subject,
Consider INDOOR LIGHT POLLUTION.
Even a little bit of light prevents humans from sleeping as best they could.
I often sleep on the sofa in the livingroom (which is a "great-room concept to the kitchen)
I was amazed how much light there was one night:
Clock on the microwave
Clock on the stove
White "sleeping" LED on my Mac laptop
Blue light that blinks while cell-phone charges
Streetlight coming in through window
I unplugged, and then replugged the microwave to clear the clock, flipped the cell phone light-side down, and used the computer sleep feature with the screen up instead of down, which makes that light MUCH dimmer.
I am sure doing these things helped save a little power, but more importantly, it made my house feel more calm.
In a bedroom, you might want to spin a backlit LCD or LED clock around or face-down to keep it from lighting up your room at night.
If you are buying a new clock, get an analog one that runs on a AA battery or get a plug-in LCD which is NOT backlit.
I have also heard that people who wake up in the middle of the night and see what time it is on the clock, often get stressed out about it and then can't get back to sleep!!!
Save power, save your sleep, be stress free.
Kill the clocks.
Old 10-02-08, 01:20 PM   #10
SVOboy
SVOboy's Avatar
Any news on this front, tim?
microwave, standby
