Old 07-15-12, 11:56 AM   #1
D.V.S.Mani
Positive Renovator
Default DIY Windspeed Data logger
Hello guys,
This is my first post & I'm Happy to be one of this community.
I've built a Vertical axis Wind turbine for domestic use it provides sufficient o/p at the moment in a weak wind regime for lighting up half a dozen 6 watt LED lamps around the house during the night. To quantify the results, I want to log 24 x 7 (and print) , the windspeeds for which its o/p is > 15 Volts D.C ( for charging a 12V battery). The requirement is a datalogger which
1) averages windspeed over a given period, say, 2 minutes,
2) averages the corresponding D.C voltage from the PMG
and store the 2 values in internal memory.
3) Serial or USB output for taking a printout everyday .
As I'm a DIY person, I would appreciate any suggestions.
Regards,
Mani
D.V.S.Mani is offline   Reply With Quote
Old 07-16-12, 06:00 PM   #2
Patrick
I suggest you check in over at windgen.org discussion - windgen.org discussion
Old 07-17-12, 08:18 AM   #3
D.V.S.Mani
Positive Renovator
Default DIY Windspeed datalogger
Thanks for the suggestion. I'll look up windgen.org
Regards
Mani
Old 09-24-12, 10:52 PM   #4
crookedninja5
You could use a microcontroller with it.
crookedninja5 is offline   Reply With Quote
