Advanced Search |
03-31-12, 01:32 PM | #61 |
I understand why you'd do this, but no superinsulated house I've seen does this. Do you know why?
03-31-12, 01:33 PM | #62 | ||
You Ain't Me
Does what?
My project: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Chipping away on a daily basis. Quote:
03-31-12, 01:45 PM | #63 |
All the superinsulated houses I've seen must have the dew point in the middle of either a blown in cellulose or blown in fiberglass wall.
03-31-12, 01:47 PM | #64 | ||
You Ain't Me
Yeah, that's fine. The dew point has gotta be in the wall somewhere. The problem is when that dew point is behind a vapor impermeable substance.
I just thought I'd add that the local up tight building inspector here let me put only 1" of polyiso on the outside of a wall that already had something like R35. He wasn't concerned with the ability of the wall to dry because of the massive hygroscopic value of all it's cellulose.
03-31-12, 01:53 PM | #65 |
So, if I blew in say... 10" of cellulose for ~R37 on the inside, then put 3" of foam on the outside at some time in the future I would be fine.
03-31-12, 01:57 PM | #66 | ||
You Ain't Me
You'd be better than fine!
But the dew point exercise is still very valid. There is a method of building called REMOTE or PERSIST which entails building a house, warping it in ice & water and then installing 100% of the insulation on the outside. There is no insulation in the walls. This all started in Canada or Alaska. Somewhere really cold. They wanted to completely eliminate the possibility of the dew point being inside anything that could rot. That's where I got the idea for wrapping my board sheathed house in bitchathane. There will be some cellulose in the walls because cellulose makes for a healthier house but the brunt of the work will be done by the foam. It sucks but I don't think it sucks as much as tearing out every exterior wall. I'm not going to put myself or my family through that nonsense. Also, you're talking about something like an R 60 wall. That's a lot of work you'd have to go through to get the 10" cavities in every room. It would be a gut renovation. Even if you have R 1 bazillion, you like an a 1,000 Sq. Ft. house with wall so thick you end up with a 1oo Sq. Ft. room, if it's not air tight, and I mean really really air tight, it's not going to pay off. The difference between R30 with 1 ACH @ 50 Vs. R 1 bazillion with 2.5 - 3 ACH @ 50 might not be noticeable.
03-31-12, 02:19 PM | #67 | |
03-31-12, 02:21 PM | #68 |
So, even with the dew point in the cellulose there won't be issues?
As you can see, I'm still pondering what exactly to do. For the office I have as much room to do basically whatever I want. For the upstairs, as I said I have small rooms. I don't want to loose much room on the exterior walls. However, I think I can live with loosing 6" (though less would be better if you have any suggestions). With my rough cut 2x4s that gives me a cavity of 10" depth and I can get darn close to R40 that way. If I do the outside I can decide what to do then, its not on the short list of things to do though. In the meantime I will work on sealing as that is still quite bad in the house. However, I wonder if that wouldn't be easier to do from the outside... Suggestions?
03-31-12, 05:06 PM | #69 | |||
You Ain't Me
Turns out you came through any way! Ha ha.
03-31-12, 05:17 PM | #70 | |||
You Ain't Me
Tags |
bamboo, diy, flooring, hydronic, remodel, superinsulate |
