Old 12-06-10, 06:47 AM   #1
Default Got a TED 5000
After the work on calculating my base load I decided the only real way to know exactly what is going on is to get a whole house monitor. So, I recently got a TED 5000-G. This is the most basic TED 5000 unit and it has been wonderful so far. With it, I have been able to find out that I've REALLY been short cycling my furnace, and have been able to identify many other loads that I never would have been able to before. However, I am still learning about it and how to use it.
Anyway, I thought I'd post up real quick on the installation. Its very simple and only took a few minutes. Reading the instructions probably took longer than the actual install.
Here is what comes in the kit.
The first step is to pop open your electrical box (if you don't know what you're doing here, get a pro). The two wires on the wire harness connect to a empty 240V breaker. I didn't have one, so I think I'm piggybacking using my oven circuit. This is not recommended.
Next, you put the current sensors on the lines coming in from outside.
And, then you hook them both up to the control box.
Now, you plug the receiver box into an outlet, and run a network cable to your router (or computer if you don't have a router).
Last, you install the software and bring up the TED monitoring system on your browser. This gives you this interface. Which shows you all of your data in real time as well as logging data.
ID:	1116   Click image for larger version
ID:	1117   Click image for larger version
ID:	1118   Click image for larger version
ID:	1119   Click image for larger version
NeilBlanchard (07-17-12)
Old 12-06-10, 01:46 PM   #2
Good for you! That's taking energy monitoring to another level
On their site I found a FAQ, where they claimed:
Q. Will TED 5000 work in 230V/50Hz electrical infrastructure (like Europe/Australia)?
A. Not at the present time. We hope to have it available by Aug/Sep 2010.
But it doesn't seem to be available yet.
Old 12-06-10, 03:13 PM   #3
Default Ted 1001
Nice.. I like it, the software is impressive looking.
But I need a unit that doesn't need a computer.
The basic $120 TED (without foot prints on it).. Looks like a great machine.
The manual seems to say it has alarms for voltage and kw. (and other stuff too).
And these can be set to 0.1 volt and .01 kw (in 10 watt increments).
I need to see what kind of juice my Sanyo is using and I need those alarms..
Is there anyone here with a TED 1001, maybe give us a review of the alarms?
My Efergy Elite monitor is being jammed by RFI from somewhere.
Making the display go blank when I really need it to be working..
Plus, the KW alarm increment is coarse. 1 kw per click..
So, I might be calling Mr. TED soon..
Old 12-06-10, 05:34 PM   #4
The one thing I really don't like about the TED 1001 was the resolution on the watt usage is 10 watts, the 5000 is 1 watt.
You can get a non-computer readout for the 5000, but it costs another $40.
Old 12-06-10, 05:59 PM   #5
On their website, I saw a $49.95 remote display that looked wireless.
I'm trying to get away from wireless stuff. It's too subject to RFI.
Add in the $199.95 5000G and it's $250. More than twice the price of the basic model.
Old 12-06-10, 06:01 PM   #6
st2288
I replaced a couple of my breakers with twins and that free up for a 15 double pole breaker.
I used that elusive for the TED 5000. That will eliminate a lot of the line noise too which can affect the reading.
st2288 is offline   Reply With Quote
Old 12-09-10, 05:37 PM   #7
I'll be very happy with 10watt resolution. If it's accurate.
My wife is getting me the TED 1001+Footprints for X-mas..
Can't wait for that UPS Santa..
Old 12-10-10, 06:59 AM   #8
Cool. Let us know how it works out for you.
Old 12-10-10, 08:18 AM   #9
I will start up a thread when I get it. It's going to be great for the Sanyo.
I will move the eFergy current probe over to the oil-burner breaker,
and set it for 125vac and tweak the rates, so I can watch both the
run time, based on the kWh used (at a known steady wattage)
and maybe I can reset the carbon cost parameter to reflect the total cost of the oil burnt..
It got down to 8.1 °F this morning, so I was running in hybrid mode last night.
Opened the free-flow from the oil burner, and bypassed the timer..
So, even at extra cold temps, the house was toasty this morning
and the Sanyo used a pretty normal amount of kWh.
6 kWhs during the 9 hours since midnight. About 667w per hour on average.
Without Hybrid running, it would have been closer to 1kw per hour.
Having the oil-assist running in free-flow saves a bit on power,
since there is no pump involved.
The burner is set to burn 1GPH, but I have no clue what it did last night.
It could have burned between 0.5 and 5 gallons while we slept..
So, putting the efergy meter on the oil will give us the data
to know what the total $ cost is..
Old 07-13-12, 06:32 PM   #10
strider3700
dragging this one up from the dead.
I'm thinking about getting a TED 5000. there appears to be 2 or 3 parts looking at the install video First is the part that gets wired into the panel and has the clamps to measure usage. I'm assuming it's wired in to draw it's power directly from the panel rather then being plugged in.
The next part receives the signal from part 1 and passes it into your router making it available online.
3rd part is the wireless display if wanted.
I'm curious how far part 2 can be from part 1 and still work? my breakerbox is in the rec room about 25 feet from my router. is this likely to work? I'm not sure if there is a limit to data over power transmissions. Also does this part need a ground on the plug? the 1 free plug in my office not filled with power bars only takes 2 prong plugs.
Also for everyone that has one are you still loving it? $200 is a little steep but the software and so on looks real nice.
energy monitor, ted
