Old 05-16-19, 10:55 AM   #1
pinballlooking
pinballlooking's Avatar
Default Plasma Cutter Track
I am think about making a plasma track cutter. Yes a CNC plasma table would be so sweet.
I think I can make a tracker pretty quick and pretty cheap.
For my projects 3' should be enough maybe 4' at most.
I think I will make this one this weekend. It is just a square made into a cutter guide.
Ultimate Plasma Cutting Straight-Edge
ID:	8619   Click image for larger version
ID:	8620   Click image for larger version
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
Old 05-17-19, 07:01 PM   #2
What do you foresee using this on?
Old 05-17-19, 10:29 PM   #3
pinballlooking
I am not sure I am going to make a track now. I really like the clean straight cuts you can make with it.
I am going to make the modified builders square one. I just bought a builder’s square to make it.
I have been using my new cutter and as long as I have a guide, I am doing a pretty good job cutting straight. I got a stand off that really helps.
I was using my plasma cutter tonight and my welder ground was connected but I thought it was my plasma cutter ground. (They look the same)
I was trying to cut ½ plate. It was not working very well at all. I messed my tip up. Then I saw my ground was not connected.
It cut so much better with the ground connected.
EV Chevy Volt -
Daox (05-18-19)
Old 05-19-19, 05:06 PM   #4
pinballlooking
Here is what I ended up making.
My old square was in very bad shape. I kept the new one I bought and cut up my old one.
This really helps in making quick straight cuts. Very cheap to make.
ID:	8628   Click image for larger version
EV Chevy Volt -
