Old 10-30-18, 07:18 AM   #1
ttpvt1
Default Voltage on one lead of solar panel
Can someone explain what the voltage on one lead (+ or -) of a solar panel is?
Obviously testing voltage from one lead to the other is Voc.
From experience, testing voltage from one lead to ground shows a small initial voltage which quickly dissipates to 0. Does this mean that touching the bare conductor from one lead of a panel (or string) presents no shock hazard?
ttpvt1 is offline   Reply With Quote
Old 10-30-18, 05:26 PM   #2
philb
You should not get any voltage on a solar panel from only touching one lead (+ or -) to ground unless it's grounded somewhere. I do check this because I don't want there to be any voltage. If there is, I could get electrocuted when I have to work on my panels.
Some charge controller companies tell you specifically not to ground the panels. NEC also has exclusions for not grounding the negative lead but does ground the panel frames.
"From experience, testing voltage from one lead to ground shows a small initial voltage which quickly dissipates to 0. " This could be due to a small amount of static electricity or the VOM self calibrating.
Old 11-02-18, 10:45 PM   #3
The momentary reading is indeed static electric charge. In every electric circuit, there exists a small amount of capacitance between the live circuit and everything else. When you probe the circuit, the measurement will not stabilize until the capacitance is discharged. A more sensitive (high impedance) instrument will take longer than a less sensitive instrument to drain the charge.
