Old 08-10-16, 04:25 PM   #1
randen
Uber EcoRenovator
Default Chevy Volt battery upgrade for S-10 EV
I realize an automobile is not anything related to home energy conservation but an electric vehicle can certainly help the bottom line when it comes to expenses. It can be looked at as low hanging fruit as the cost of energy to power an electric vehicle is a lot less than to power the fossil fuel machine to operate. For us the cost of gasoline per year is the next largest cost. We wrestled the monster down regarding home heating and lighting with Solar Hot-water space heating with Geo-thermal back-up, LED lighting and with more efficient appliances.
With my shop the same has held true Geo-thermal and more efficient lighting. A little more insulation and the later model CNC machines are extremely efficient.
If any have been following my adventures with the Chevy S-10 EV it is now operational with 16 yr old Nimh battery tech. The older pack proved our new custom AC inverter drive system however battery voltage sag under load is a detractor from the capabilities.
I had mention on the electric vehicle post that I was quite surprised after a charge that the truck actually spun tires on dry pavement from which the batteries voltage lowered (voltage sag) quickly.
The now hot rod S-10 needs some good batteries.
1st thought: Tesla batteries, but they seem to be almost un-obtainium
More readily available Chevy volt pack.
I found 2 so about 34 Kwh together. Removed the old Nimh and have repurposed these for the house. This will be another chapter to be caught up with later.
The 2 chevy volt Lithium packs are now reconfigured to be placed in the OEM battery box that is positioned between the frame rails of the truck. However about 4 kwhs remaining are left to be placed in another box behind the rear axle.
Things are going to be exciting with some batteries that will have very little voltage sag and possibly enough range for 120 miles.
Randen
ID:	7133   Click image for larger version
ID:	7134   Click image for larger version
ID:	7135   Click image for larger version
ID:	7136   Click image for larger version
The Following 4 Users Say Thank You to randen For This Useful Post:
Daox (09-07-16), jeff5may (05-29-17), ME_Andy (08-10-16), pletby (09-04-16)
