Old 07-30-14, 10:43 PM   #11
Originally Posted by gtojohn View Post
Is it possible to add a return air duct to the downstairs? Or if there are 2 seperate supply ducts make one a return? The idea being to help remove the extra air which is too cold and allow it back into the system.
Careful. If you add a return and there is no corresponding supply air, you'll create negative pressure in the basement which will pull air through every leak imaginable which can add humidity, radon, drafts, etc. to the space. If there are any natural draft appliances(most natural gas water heaters are a common example), you can backdraft that exhaust into the living space.
If there is no supply venting, don't add a return.
Old 07-31-14, 09:15 AM   #12
MetroMPG
Infrequent noob
Found out the basement already has a return.
The door should be ready in a couple more weeks.
Old 09-05-14, 12:08 PM   #13
MetroMPG
Infrequent noob
Default Door is in... last day of "summer"
Well, their new door went in Wednesday.... And summer is over!
Today looks like probably the last A/C day in the forecast of the next 2 weeks (and therefore also probably for this year), so I won't be able to gather any info on how well it works.
Someone bump this thread in 2015 and I'll get some temperature readings on either side of the partition when the hot weather returns and the A/C is blasting.
