Old 10-17-12, 12:09 PM   #11
hamsterpower
That's one of the nice things about masonry (and mud, dirt) walls that thick. When humidity is high they absorb moisture, when humidity is low they give off moisture. It can help regulate humidity.
Old 10-17-12, 02:57 PM   #12
SimpleManLance
The thermal mass of the walls must really soak up some heat. It doesn't look like there is any insulation on some of the wood ceilings. Seems like there would be a lot of heat loss out the windows and ceiling.
EDIT: so further research shows that there is fair amount of insulation.
http://youtu.be/wTqSpx0Vgv4
Jack of all trades, master of none.
SimpleManLance is offline   Reply With Quote
Old 10-17-12, 06:04 PM   #13
In years past I helped build a couple of rammed earth houses and an adobe house here in Ontario. No insulation was necessary, the rammed earth walls were 2 ft thick and the source of heat was a masonry wood stove. It didn't need anything else, other than solar for power and for DHW.
Old 10-17-12, 06:42 PM   #14
S-F
You Ain't Me
S-F's Avatar
There is a great BSC paper on earth as insulation. I'll dig it up and post a link to it tomorrow when I have time.
EDIT:
http://www.buildingscience.com/docum...er-green-roofs
My project:
