Old 12-15-17, 10:51 PM   #1
Default Better bathroom fan
I have a bathroom fan I'm using as a forced air fan for a fire place heat exchanger. It was probably the cheapest one they had at the time.
It's noisy and now that I expanded the fireplace heat exhanger it could us a little more flow.
Anyone have any recommendations for at least a quietish one, higher flow would be nice too but don't have to have it.
A computer fan won't work, already tried.
Old 12-18-17, 04:47 AM   #2
Zelim
Try to buy one cheap on ebay?
Zelim is offline   Reply With Quote
Old 12-18-17, 06:47 AM   #3
I have a cheap one now, I think it's the $15 one, it's real noisy.
There is one on the shelf at Lowes that is supposed to be pretty quiet but it's $100. If it's not quiet enough I can return it and special order the super quiet one for a $140.
Old 12-20-17, 01:03 AM   #4
I bought a Delta Breez for about $60. 80cfm, uses only about 12 watts, rated for continuous use, 0.8 sones. You can hear it but most of the noise you hear is the air it is moving. Uses 4" duct. There are higher capacity and quieter fans but if you want either you need to go 6" duct or you'll be burning more energy and making more noise.
oil pan 4 (12-20-17)
Old 12-20-17, 07:47 AM   #5
A lot of fan's noise is in how they're mounted. The quieter bathroom fans are remote mounted, or hung to reduce vibration and distance from the user.
Old 12-20-17, 08:49 AM   #6
I have an old speaker box I'm going to put it inside along with some egg crate foam.
I need that delta breeze fan. Where did you get it?
Old 12-20-17, 03:09 PM   #7
I got it from Menards.
This is the same one I bought.
https://www.menards.com/main/bath/ba...5701251&ipos=1
Old 12-22-17, 11:39 AM   #8
The quiet ones don't seem to generate the same pressure ad the noisy ones.
bathroom fan
