Old 06-16-15, 08:18 PM   #1
MEMPHIS91
MEMPHIS91's Avatar
Default Homemade Retangular HVAC Ducts
Howdy guys I got a quick way to save some big bucks on redoing the old or putting in new duct work. I needed to replace an old undersized/under-insulated 8" round metal duct in my attic. It was trying to run 4 registers. So I priced some metal rectangular truck to come off my main plenum, 24 feet long 10" x 12" was a whooping $675! That's not even installed. So I started looking into what would be needed to do the job right. Here is what I came up with. $150 total cost.
Parts list (all from Home Depot)
Owens Corning FOAMULAR 3/4 in. x 4 ft. x 8 ft. R-4 Tongue and Groove Insulating Sheathing-37L - The Home Depot
GAF 0.5 in. x 4 ft. x 8 ft. EnergyGuard PolyIsocyanurate Insulation Sheathing-1S01 - The Home Depot
Master Flow Water Based Mastic Half Gallon Tub-WBA50 - The Home Depot
3M 17.6 oz. High-Strength 90 Spray Adhesive-90-24 - The Home Depot
So I took the foam boards to the table saw and cut my pieces out.
I cut the PolyIsocyanurate (with vapor barrier) smaller to be 3M spary glued to the FOAMULAR .
This is some crazy awesome stuff! Its water based too so it washes up really easy.
I the coated EVERY seem VERY well with the mastic and glued them together. I then came back and coated the outside of each seem as well.
All done. I just have to make up 2 more and replace the old with the new. This should give me a R valve of over 7. Finished inside size of 13" x 9".
ID:	5454   Click image for larger version
ID:	5455   Click image for larger version
ID:	5456   Click image for larger version
ID:	5457   Click image for larger version
ID:	5459   Click image for larger version
Old 06-17-15, 07:41 AM   #2
Hah, very nice!
I wonder how the mastic will hold up over the years though? I suppose that is pretty much what it is designed for...
MEMPHIS91 (06-17-15)
Old 06-17-15, 09:35 AM   #3
MEMPHIS91
MEMPHIS91's Avatar
Thanks. It should last a long time. But foil tape will be added to all seems after installation.
Old 07-15-15, 09:52 PM   #4
MEMPHIS91
MEMPHIS91's Avatar
Got the ducts roughed in. Old 8" hard pipe = 160 CFM. New foam ducts = 600 cfm.
roflwaffle (07-19-15)
