Old 01-05-12, 02:15 AM   #11
"The house was long, East/West, and narrow, North/South. It had the usual overhang to shield against summer sun, was backed into an earth berm on the North side. Had an abundance of windows along its South face, an insulated concrete floor to store heat (no hydronics) and something like R-60 in the roof. It has a wood stove in the living room that supplies heat to the whole house... there's a free-standing stone wall behind the wood stove to capture and slowly release heat from the stove."
You seem to be describing what I'd build. A long east/west house with southern windows, overhang blocking summer sun, my original post was about having exterior of the house underground a bit, I'm thinking R75 roof.
The difference with mine is that I'd go with a ductless minisplit for heating and cooling instead of wood. I'd like to go all electric even though I love cooking with a gas stove(might go with propane for that). Reason why I'm not look at a gas furnace for a mostly passive house stems from my current experience from my 2150 sq ft house where 36% of my gas bill is connection fees, city franchise cost, etc. This house is not passive and has no south facing windows. Managed 31 therms($31) in our extremely mild December, warmest December I've ever experienced here. Natural gas total cost for 2011 was $350, fixed fees being $130 of that. Basically what I'm saying is that natural gas is expensive when you don't use any. In my current situation, I need enough heat to where going all electric doesn't make sense but for something mostly passive, it does. I'd probably use a space heater as my backup heat since I already own it, maybe turn the toaster oven on if I really need it, a hair dryer but I'm not looking to need 15k BTU, if I can manage to not freeze the pipes with a 5k BTU(standard 1500 watt space heater) or less I know I'm all set. I don't want to deal with wood, even if it is only a cord a season. Only needing a cord is amazing though, I suppose that's just a couple logs on the colder days.
Old 01-05-12, 10:47 AM   #12
I asked him if he would make any changes, and he said that he wished he'd put more insulation in the roof.
Just to keep things in perspective for you, the area where I live, has a Heating Degree Day rating of about 4,500. It looks like where you are, HDD is about 8,000. Our winters are fairly mild and direct sunshine is obscured by the clouds that blow over from the Pacific ocean. I'd imaging your winters are more of a challenge, and that you have more solar energy available.
I think mini-splits are great, I sure like mine.
However, I have been pursuing the practice of keeping multiple modes of heating & cooking, where possible. Although not as bad as it was, we still have power outages from time to time, and I'm always glad that my gas range still functions. I have a wood stove in the basement, too.
My gas demand water heater uses two D-cells as it's ignition source, so power outages don't affect it either. Once when we had a power outage, I went in and took a long hot shower by candle light, just because I could. It was a very practical luxury.
[QUOTE=MN Renovator;18850]...Basically what I'm saying is that natural gas is expensive when you don't use any...[QUOTE]
I'm with you on that one. I'm tempted to go propane for that reason. Most months, my gas use is less expensive than the fixed fees that are tacked on. But right now, the difference doesn't outweigh the cost & hassle of switching over.
I'd probably use a space heater as my backup heat since I already own it, maybe turn the toaster oven on if I really need it...
Here's an interesting type of small heater, that is wall-mount and direct vent (combustion air in, exhaust gas out) and is very unobtrusive. Some brands of these are able to be retrofitted to run on either NG or LP gas. It has no pilot light (uses piezo), and uses no electricity to operate.
I think one of these should be in my kitchen.
Old 01-05-12, 08:51 PM   #13
I was thinking an appropriately sized gas generator for the event of power outages. The largest load would be the water heater at 5kw since the heat pump would use less. I could go with a heat pump water heater instead but I'm not seeing it worth it unless the electrics have terrible insulation. The Honda inverters now go up to 5500 watts rated and run for 14 hours at 1/4 load off of a 4.5 gallon tank so I should be okay if I carry a decent amount of gas on hand. It might not be cheap or as ideal as using propane for water heating, clothes drying, or the stove but it eliminates the need for another fuel source, and propane is quite expensive to where I'd almost rather use a gasoline backup for the electric.
Old 04-16-12, 03:51 PM   #14
Drake
DIY Guy
Earth berming was a popular direction in the 70's for energy conservation. I know people that built them. The fact that they are not still popular say a lot about their practicality. Two of the three have constant ongoing drainage problem and all three have humidity and possible mold issues(in MN). They are quiet and blend with the landscape. One even has a sod roof. But they need way more space and are more expensive per sq' that super insulated or passive design. I had planned to build one but didn't. People left the sod house concept behind for a reason.
I also don't see air/air HX as very effective in our cold winters. I think hydronic heat would be a better choice which gives you several choices on how to heat the water. Of the many "green" energy concepts that I have followed since the 70's I'm looking at the one that are still working out. Like passive solar(thermal mass), hydronic heat, super insulation, space conservation, indoor pollution control, EF appliances/lighting, PV generation, SDHW(location dependent), DIY knowledge/skills. Seen many great ideas flash, consuming peoples valuable money with no return possibly even threatening their very health(molds, raydon, contaminated water.
Old 04-16-12, 11:51 PM   #15
Originally Posted by Drake View Post
Earth berming was a popular...Two of the three have constant ongoing drainage problem and all three have humidity and possible mold issues...People left the sod house concept behind for a reason.
You have pointed out the potential problems with berming, but the problems can be overcome. I have a friend who lives in a bermed passive solar house, which is tucked into the side of a hill here in rainy Oregon. Proper drainage and damp-proofing was designed into the structure from the beginning. The house is dry and cozy and requires very little additional heat in the winter, and no A/C in the winter. So don't be too quick to toss the baby out with the bathwater.
There sure was a lot of activity in the 70's regarding energy efficiency, and a lot of good books written on the subject. I always keep an eye out when I'm in a used book store for 70's alternative energy books... I have amassed a fairly substantial vintage DIY alt-energy library.
But Drake, you are right, some of the ideas stood the test of time much better...
My Dad used to say it's much easier to have 20-20 vision when you're seeing things in the rear view mirror.
Old 04-17-12, 07:17 AM   #16
I don't see the issues with berming being that great considering that the house I live in is undergrade without any issues. It seems that as long as you build it with the same considerations as you would with having that bermed area being a basement, I'm not seeing the issue. I see houses all the time with walkout basements in the back of a house where the front of the house is flush with the ground or maybe a step or two above. That sort of house is effectively bermed. Of course the correct solar exposure is fairly critical. In the case of a house that I know of where the owner discussed energy bills, he says that the summer air conditioning is far higher than the winter heating due to almost all of the glass being on the south.
The more that I reading about passive house building and using glass to assist with heat in the winter, whether it is double pane, triple pane, or has a pile of films(won't name the brand name) the more than I'm leaning to having very little glazing when I build a new house. In the house I'm living now, I have the drapes shut pretty much all the time because the solar exposure is terrible in the winter because the big picture windows are not south facing enough for them to get much sun at all during the winter months. My house has about 4 square feet of southern glass and it's about the only glass that brings in a decent amount of light other than the skylight. The skylight is a nightmare though, when I moved in, it had drywall and sheathing and is directly exposed the attic and had water vapor streaks from shower humidity. In the winter this kind of glass lets out all your heat and in the summer it turns my bathroom into an oven. I have little use for the light considering that if its at night I have a single 430 lumen directional LED that does the job using 8 watts. I'm putting serious consideration into having that skylight removed when this house needs to have its roof replaced. It'll free up space for solar PV panels.
So basically my house is setup so that way in the winter I get little heat from the windows and in the summer my house is baking. I had the idea of installing a removable external sheet of polycarbonate plastic or acrylic and putting Gila film on it to block light in the summer but I found out how expensive those sheets were for the massive size of the picture bay window space(three windows). I think what I'll do instead is buy two patio door screens and fashion those into a removable frame to block light and add privacy. The faux wood blinds by Levolor that the previous owners installed are terrible, don't buy from that company or go with wood blinds, these things suck in the heat and reflect next to nothing. I've hit them with an IR scanner in the summer and had them at 110 degrees in a few spots with an indoor temperature at 74 with the a/c going. They are terrible and will be replaced with honeycomb cell shades in no color other than white.
My goal is to get the a/c heat load down to 1.5 tons, I currently have a 2 ton air conditioner and on a design temp day it will run continuously(as it should) and maintain a few degrees above the set point. On a cooler day I usually operate it so it will run in a single period without shutting it off so I can remove as much humidity as possible to make a higher temperature much more tolerable and its working well. The sun-facing windows with bugscreen over the outside should hopefully reduce the load below 1.5 tons and when I replace my equipment I can confidently ask for a 40k furnace and a 1.5 ton a/c.
The reason why I'm talking about my current house is because I can see all the mistakes of this one to avoid with the next one. It seems that even though I've got limited solar exposure I can manage to get my biggest winter heating bill down to $70($60 when subtracting fixed connection fees) in winter 2010/2011 and under $45 or $35 without fixed connection fees 50 therms Jan 2012 and 180 therms for the past 12 months. These are the highest bills for a house 2200sq ft. Granted I need to disclaim that I don't keep my house at 75 in the winter, I allow it to get as cold as I am comfortable living in, same goes for summer. It's too big for my uses but when I bought it, I was buying a house that fit the neighborhood that I want to live in. Happens to be this is a neighborhood mostly with families and not very many singles or couples so the idea was to buy a house that I could sell later on down the line. A future house would likely be in a college campus area where houses that are built under 1000sq ft for one or two people or maybe 2 people and a kid(I'm talking about the average demands of a family, not what I'd live in with 3 or 4 people). I'm willing to live in a small place even if it were a family of 4 but I won't build for a family of 4 when I'm single.
Back to the topic of glazing, I'm not seeing the advantages as far as cost/benefit goes when going beyond either a really good double pane with the appropriate air gap or triple pane windows with almost all of them on the south side of the house and keeping them sized small and using a fairly substantial amount of cellulose and of course appropriate air sealing. Going completely passive seems to have lost it favor for me after seeing a Duluth, MN project get denied the passivhaus standard because they couldn't make the .6 ach50 but were very close. That house is passive though even though it didn't meet the standard. My goal is to lose the $10.50 connection fee with the natural gas provider or whatever that fee is and having heating costs be under $126 in electricity with a combination of a 9k BTU/hr heat pump and resistance heat for when we get below 0f and that thing can't produce, or in case the heat pump decides to fail. I'm still sticking to my 5k BTU/hr design load goal at -20f. The actual heat design temp where I live is between -12 and -15f depending on where I check but I'm not far from an area north that seems to be -18f. With insulating to a 5k BTU/hr heat load at -20f I'm not seeing much reason to rely on the sun for heating and it seems to be a better plan for me to consider keeping the sun out during the summer. It seems passivhaus designed use an earth tube and a condenser to do the job. Earth tubes are expensive and it seems that more and more of the project I read about are not doing this. Instead of going completely passive, I'll skip some of the more expensive steps and goals of building the status and going with what works on my terms. Things like the ASHRAE ACH for a house are IMHO way too high. I've done the math, if my house was communicating that many air changes, I'd be frozen out of my house for how much heat I'm putting into it but I have a hard time believing that a little breathing, humidity, and human sweat are as terrible as people make them out to be. IMHO controlling humidity to prevent mold is a much bigger concern that any ventilation system in my area will only require much more air conditioning in the summer to pull the humidity back down so the dew point is below 50f to make the basement safe.
Old 04-17-12, 02:37 PM   #17
If I'm not mistaken, the ASHRAE standard for homes has been adjusted downward.
You might want to check that out...
Old 04-17-12, 10:25 PM   #18
The latest version of ASHRAE's manual that specifies ventilation or required infiltration prior to adding mechanical ventilation shows .35ACH prior to adding mechanical ventilation.
Personally, I'm on board with 15CFM for person. I think doing a bulk air exchange of that amount over the period of time during the day that is most favorable to the indoor temperature. Not to code, probably not officially recommended but anyone but I'd prefer it.
Old 04-20-12, 08:17 PM   #19
RobertSmalls
RobertSmalls's Avatar
I've sketched out a few hypothetical houses myself. Maybe I'll make one of them into reality in a few years.
I was explaining the "tiny house" concept to a co-worker, and he told me about all the time he spends on his sailboat. In a boat, as in a tiny house, it's more about cubic feet than square feet. By utilizing the full height of a kitchen, having tall bookshelves (with electronics on the middle shelves, perhaps), and having a sleeping loft instead of a bedroom, you can get a lot more value out of each square foot. I see too many houses where there is nothing of utility on the top half of each floor. With a good floorplan and some efficient furniture, I wouldn't have a use for more than about 400ft².
The front yard is strictly for curb appeal. I'd place the house close to the street, and keep the small front yard looking good. There would be room for a few fruit trees in the front yard. I wonder how well a blueberry hedge would work. The street would be on the north side of the house, so that most of my windows would look out on the garden.
For me, the challenge is building a house that's far more efficient than a conventional house, but making it look very ordinary. The house has to look good from the street, and I'll have to make it look bigger than it is. Landscaping can help, as would 12" thick walls. I'd also use an attached garage to my advantage.
I want at least a two car garage, but I don't want two thirds of the front of the house to be garage doors. I like the idea of having the garage doors on the side of the house. I could add a large window with nice curtains to the side of the garage, to make it look like the house is bigger than it really is. This works especially well if I were to go with a "double deep" 2x2 car garage/lab. The garage would have concrete + epoxy floors, 2x4 construction with insulation behind OSB instead of drywall to keep costs and mantainence down. I would install an ordinary 45000BTU/hr furnace in the garage, to heat it quickly on demand. Maybe the south wall would be solar collectors for the house and DHW.
You should do the math on how much energy you use in the house vs. the car, and let us know how long a commute could get before cancelling out the savings.
I've always wondered, what drives recommendations for >R50 in the attic? Would it be different if you had a good heat-rejecting roof, such as one made of shiny metal, painted white, or covered in solar collectors?
Old 04-20-12, 08:58 PM   #20
I always thought the idea of more insulation in the roof came from the vented aspect of the roof increasing the surface heat conductivity of the insulation since there is air flow directly over it requiring more insulation while the walls are sheated and essentially have a layer over them. In the winter with the ceiling having the hottest air that supposedly you'd want more insulation there. Not to mention it's easy to load a whole bunch of loose fill cellulose up there. In my case it's about the only place I can add cellulose to my current house without tearing out drywall, which makes it a large and easy retrofit opportunity. As long as all air sealing opportunities aren't missed before loading a pile of treated paper up there, it's about one of the only options for adding R-value for most. In a new house R60 might be more than enough, depends upon the standards for energy use that someone is going after, I'll have to read those sections of my Manual J again and read the factors on heat loss through the attic versus the walls so I can make comments about what ASHRAE thinks.
