Old 11-12-12, 01:10 PM   #1
TimJFowler
TimJFowler's Avatar
Thumbs up Flushed With Pride - Thanks Daox!
I was the first (if not only) person interested in a free dual-flush toilet conversion kit courtesy of EcoRenovator.org's Daox.
It took me a little while, but I've finally installed the kit on the more frequently used toilet in our home. Installation was pretty straightforward, with a few minor exceptions. First, temporarily remove the float ball and arm (if your toilet has one) to simplify positioning the dual-flush mechanism. Also, the plastic nut that holds the flush lever on the inside of the toilet tank is reverse-threaded (righty-loosey).
Flushed With Pride | EcoDaddyo.com
This project was simple and I'm planning to convert the toilet in our other bathroom to dual-flush. This is a simple way to reduce your household water use for very little cost or hassle.
Thanks again,
Tim
The Following User Says Thank You to TimJFowler For This Useful Post:
Ryland (11-12-12)
Old 11-12-12, 03:43 PM   #2
Glad to see it put to good use.
Old 11-13-12, 06:41 AM   #3
tysonlee
tysonlee is offline   Reply With Quote
