Old 07-09-14, 10:45 PM   #1
philb
Default RV air conditioning water misting
My RV air conditioning unit will not operate for very long if the temperature is over 100 deg. F.
Last year, I installed a water mister between the fan and the condenser coils. That allowed the unit to cycle on for 20 minutes and off for 10 minutes at 100+ degrees.
I've used misters in the same fashion with 5000 BTU window hangers. That lowered my electric bill and kept the grass watered a little too well.
This year, I want to add a electric valve to turn the water on and off when the unit cycles. A 120 VAC valve would be the best IMHO, but I'd settle for 12 or 24 Volts AC or DC.
Suggestions are appreciated. Part numbers would help too.
Old 07-09-14, 11:11 PM   #2
Just get one from a broken dishwasher or washing machine.
Old 07-10-14, 01:08 AM   #3
Water injection - EcoModder
Nothing is 120v on there. lots of nozzles and related stuff.
Were you able to quantify the savings on the window units?
Old 07-10-14, 11:17 AM   #4
philb
I don't remember attempting to quantifying the savings on the a/c unit. That was before they began building units that would hold water in the bottom tray to sling into the condensers.
