Old 03-12-13, 09:12 PM   #1
philb
Default white concrete colorant
I'm looking for ideas for a white or slightly tan colorant for the last layer of ferrocement. (Ferrocement is a thin mixture of high psi low water cement layered over stucco lath.) I think titaniun dioxide will work well - if I could find it at a reasonable cost. Any ideas on where I can find it or maybe you have another idea that's better. Latex paint can be mixed with the mortar with limited results.
Do we have any mudders on this site?
Old 03-12-13, 09:45 PM   #2
sunspot
Not sure of your application but white cement (expensive) and silica sand (also expensive) will give you white.
The Following User Says Thank You to sunspot For This Useful Post:
philb (03-13-13)
Old 03-13-13, 08:13 PM   #3
philb
Yes, white sand is unavailable locally, but the cement is available and very pricey. Thanks
Old 03-16-13, 08:30 AM   #4
Why not white wash it? I've seen it on straw bail houses and it looks great, pretty sure they just used lime and water.
Old 03-17-13, 05:41 PM   #5
philb
I prefer something permanent. I could mix the lime with the last coat. That may fit the bill.
