Old 01-03-17, 03:34 PM   #1
dh1
Default Hot water heater timer
This has probably be done before, many times, but.
I put a timer on my 60gal Hot Water heater, it comes on a 11pm and shuts off at 4am. I did this so my heater only comes on when hydro rates are low, 8.7 cents vs 18 cents.
I have never run out of hot water, doesn't matter if I shower in the morning or at night, or twice a day, I have hot water.
My Laundry is always done in cold water so the only other time I need hot water is for dishwashing and washing up.
I did this about 4 months ago and should of done it when I moved in.
I think if I put more insulation around the hot water tank I'd burn even less hydro.
dh1 is offline   Reply With Quote
The Following User Says Thank You to dh1 For This Useful Post:
Daox (01-04-17)
Old 01-03-17, 06:00 PM   #2
where2
DIY Geek
When I set mine, I set the timing it to utilize as much of my PV energy excess as possible, lowering what I send out to the grid as net metered energy. We've got a 50 gallon tank, and rarely noticed any difference in the temps at the tap.
Old 01-05-17, 02:56 AM   #3
WyrTwister
Default Grey box
This timer is marketed for that purpose .
https://www.amazon.com/Intermatic-WH.../dp/B00004W4XI
God bless
Wyr
The Following User Says Thank You to WyrTwister For This Useful Post:
Daox (01-05-17)
Old 01-05-17, 07:02 AM   #4
Insulation around the tank will definitely help keep the heat you paid for in the unit where it belongs. It is a quest of diminishing returns, but the cost is small for a pretty permanent solution. That being said, anything worth insulating is worth superinsulating. Due to the nature of your billing structure, spending "too much" more on superior insulation will only leverage your gains in savings.
Another great idea some other members have had success with is the use of PCM (phase change material) to boost your tank's heat holding capacity. Once unprecedented and obscure, this method has been perfected to the point where you can purchase products to fit your needs. The PCM stores and releases heat using latent energy transfer at a narrow range of temperatures. Using it has the effect of making your tank act larger than it really is.
Old 01-05-17, 08:14 AM   #5
God bless
Wyr
I have a 240v timer almost exactly like that one for my pool pump. I have been using it for a few years it works well.
Old 03-09-17, 05:11 AM   #6
LarryBertsc
LarryBertsc is offline   Reply With Quote
