Old 05-24-15, 09:07 AM   #11
vwhead77
Hey that's my PVC exchanger It didn't work for high-temp/high-side compressor HP water heater BUT I'm glad I didn't throw it away - you gave me hope to use it in some way. I ended up building an all copper HX for hot water via HP app that DOES work. Just finished the pool water experiment and that is a success as well. Anyway, cool, I'm hoping to use that damn PVC HX for something!- [go brain go]
vwhead77 is offline   Reply With Quote
Old 05-25-15, 07:57 AM   #12
Doh, you got me! How much do I owe you? Or may I just be forgiven? @sorry I didn't ask permission first.
For the record, your hx design is a proven winner. Your solid copper one is a lifer. The one in the pic can be finished leak-free. Both are dependable warriors worthy of imitation.
BTW, what is this forum's stance on copyright law anyway?
Old 05-26-15, 06:41 AM   #13
vwhead77
Default PVC HX Final Version
LOL - I really don't care - it was kind of a surprise and, to be honest, I was a bit flattered. Here is the final version after trying all kinds of seals and epoxies - I had it threaded and I used these twist on rubber seals.I thought it was a winner. It stayed tight for about an hour then just started 'seeping' a little which of course is not going to work - thus the copper version. As per your suggestion, I do believe it would be a great HX in a submersed situation such as a pool (hp to pool water - to heat pool). However, I'm not that interested in heating my pool water so I think I'm going to adapt it to use on my sailboat. I'm thinking of putting long vinyl hoses in/out and dropping it overboard while docked or resting and using a 12V pump (in a closed loop) to circulate cool water through a small evap. coil to help cool the cabin. At the very least, there is still hope for the PVC model in some application I'm sure of it Thanks for posting - I enjoy your input and suggestions.
Old 05-26-15, 08:00 AM   #14
Wow, it still lives! I figured it ended up an orphan or worse.
