Old 12-31-17, 05:54 PM   #631
Default New Years Eve 2017-2018 !! And it's cold!
Here's the odd part.. The Sanyo has been using 500 to 700 watts to heat the den..
Still putting out hot air right now.. My sensors are showing between 3 and 6 deg F outside..
I turned it back on this morning when the temp got up over 9F..
It's been running all day.. Keeping the den warm as toast. Very weird..
Normally, it would be shutting down under 10F.. Maybe the dry air helps?
Happy 2018!
Rich
Old 01-01-18, 07:42 AM   #632
Mikesolar
Mikesolar's Avatar
Is the Gree installed yet? I am wonderig because I put in a 2.5ton Gree in my shop that I got as a discontinued model. It says it will work down to -15C but that may be a bit hopeful. It goes off on a high head pressure or high compressor temp around -12-13C, waits a bit and comes back on but I know the output temp is low.
Old 01-01-18, 10:19 AM   #633
My first Gree has been installed for a while now.. Fall of 2016..
http://ecorenovator.org/forum/geothe...install-9.html
I have not purchased one for the den yet. The den Sanyo is a problem below -12C.
So, I'm waiting for the climate to turn warmer, or the noisy fan motor to die..
Then, I'll likely buy a second Gree.. This one has worked okay at -20C.. (-5F)
Mikesolar (01-01-18)
Old 01-01-18, 11:21 AM   #634
randen
Uber EcoRenovator
Last night "New Years Eve" driving home after a house party the outside temperature here in Ontario Canada read -21 Deg C. Burrr. The ground source heat-pumps purring away keeping the temp welcomingly at 20 Deg C. in the house. Very little of the in floor heat has been harvested by the Solar Hot water collectors.
A lot of snow here now and blowing around.
Its great to see that the efficiency of the ASHP is getting better.
700 watts and still blowing warm air with those outside temps!!! Amazing
Randen
Old 01-01-18, 12:38 PM   #635
It's up to 10F outside right now (Dew Point:-9.3F)..
But, the Sanyo just went orange-flashing.. Going to window-solar..
It was working pretty good before. The Gree is taking up the slack..
Old 01-05-18, 11:39 PM   #636
Default Sanyo is amazing tonight
The Den Sanyo is working great tonight. It's using 770 watts at 1.4 deg F
I had expected to be using the two 900W space heater about 6 ago.
The Den has been very warm all evening. The older it gets the better it runs.?.
Old 01-06-18, 08:34 AM   #637
st2288
unbelievable
st2288 is offline   Reply With Quote
Old 01-06-18, 11:44 AM   #638
Default It is unbelievable.
Last night, it started blinking around 1:30 AM, so I turned it off for night. Outdoor Temps were dropping slowly..
Used two 900W space heaters all night in the den. 1.8 KWh = 6142 BTUh. It was a little cool in there.
Woke up to a COLD day. I didn't think today's forecast temperatures would allow for ANY use of the Sanyo..
But, when the outside air soared up to 6.4 deg F this morning, I turned on the Sanyo..
It's still heating the Den, using 700 to 800 watts.. (See history chart below).
It's on the north side of the house, so there is Never any sun light near the old Sanyo.
I really don't understand why this thing is working so well, during some really cold days..
For the Boston area, this is really cold. Yesterday we shoveled out in a -20F windchill. Strange times we live in..
ID:	8081   Click image for larger version
Old 01-06-18, 12:20 PM   #639
WyrTwister
Global warming . It is the Republicans fault . :-)
Great to hear it is working well . :-)
Wyr
God bless
Old 01-06-18, 05:07 PM   #640
warmwxrules
@ 1.4F and 770 watts..any idea how many BTU's of heat it is giving you?
warmwxrules is offline   Reply With Quote
air conditioner, diy, heat pump
Copyright ©2000 - 2022, vBulletin Solutions Inc.
