Old 05-18-13, 06:28 PM   #21
OffGridKindaGuy
Hi-Tech Hillbilly
OffGridKindaGuy's Avatar
"hey offgridkindaguy. how long have you had the l-16s? 24v or 48?"
I've only had them installed for a few months. Prior to that, I had 4 golf cart batteries about 3 ft. from the foot of the bed. They lasted me 8 yrs..
I have them configured in 12 volts. Everything operates directly from the battery. I rarely use an inverter..
*The foot of the bed is in the right corner of the pic..*
Old 05-23-13, 01:15 AM   #22
smithsaiden
Guest
Posts: n/a
very nice and well constructed shed for solar panel...
Old 05-25-13, 03:41 PM   #23
creeky
creeky's Avatar
nice set up. Offgridguy. tho i suspect we're going off topic.
verdigo. for my "shizzer shack" (high tech washroom) I'm trying passive solar venting.
to wit: I have a metal roof. beneath that are the battens. then sheets of foil faced polyiso, then the rafters. What happens is that the sun heats the air between the insulation layer and the metal roof. What happens to hot air, it rises. The hot air is then vented out through the ridge. It draws cooler air up from the outside edge.
Now I'm just letting it work like that to reduce heat coming into the washroom. But in one of the posts I found the researcher (sorry, thought I had the link, but...) cut holes in the polyiso down by his walls. This allowed the convection current to draw air from his attic (in his case) up through to the vented ridge. This reduced his attic temps from 140 to 80 (if memory serves ).
I can say that the system works. I don't have documented temps, but shortly after finishing the roof we had a day where it was -2C (about 29F). With two large windows on the south wall of the shack the interior temp of the shack rose to 7C (42F). Perfect for me. I want solar heating. But on the north side of the shed the snow which had fallen during the night remained frozen on the roof. The only explanation is that the convective current was keeping the metal roof at below freezing.
Rather than a fan you could harness the same principal for passive solar cooling. I recommend it to anyone trying to cool their house.
Old 05-25-13, 03:59 PM   #24
OffGridKindaGuy
Hi-Tech Hillbilly
"nice set up. Offgridguy. tho i suspect we're going off topic."
Mebby.. Just sayin' that I keep my battery inside with me..
Old 06-21-13, 08:34 PM   #25
verdigo
I am ready to hang some panels. Still trying to design a secure angle adjustable mounting system. I will probably use stainless angle to mount panels to the ground mount. Here are a couple of updated pics
verdigo is offline   Reply With Quote
Old 06-22-13, 10:03 PM   #26
where2
DIY Geek
That's going to be a serious upgrade over the 3 amorphous panels I think I see sitting by the other shed.
Old 06-23-13, 09:29 AM   #27
verdigo
Yep. The Harbor Freight Solar Kit. I suppose the gateway drug.
Old 06-24-13, 07:53 AM   #28
Looks good!
verdigo (06-30-13)
Old 07-12-13, 09:40 AM   #29
Have you got the panels attached yet?
Old 07-22-13, 09:44 PM   #30
verdigo
Not yet. I bought some IronRidge rails but Have not attached anything so far. I only get weekends to work on it and have been getting rained out or had to do other things not as interesting. I wish the Solar fairies would show up.
Dennis
