Old 04-12-11, 01:40 AM   #11
ThatSolarGuy
ThatSolarGuy's Avatar
Default - calcs for solar production
I agree for the most part with Xringer's math. I use 5 hours a day in SoCal. 5 hours may seem low, but when you factor the entire year (cloudy days), 5 hours is actually pretty good. In your region 4-4.5 might be more accurate.
Here's the calc I use everyday
MODULE WATTAGE x # OF MODULES X .76 x # HOURS = kWh/day
FYI .76 is a factor derived from...
most inverters are about .96 (96% efficient)
most modules run at.90 of their nameplate (the CS 200's generate about 180Watts
voltage drop is max of .98 (system designers will select conductors to max this at 2%)
system design is .90 (system design is the delta from ideal positioning of your array) ideal being true south and angle or tilt = your latitude. So .90 assumes your losing 10% due to less than ideal mounting conditions.
When you multiple all those factors you get .76
So I'm going with 9.6kWh per day from (14) CS 200 polys in the N.E. ALL your hardware could be procured for about $3.15 per watt (DC watts that is) or $8,820. Now that's before any rebates or incentives, and as Xringer says, that's a lot of years of electricity at just 400kWh/month. Google DSIRE for rebate info in your area.
Blue Skies,
Jeff
BTW Right now module prices are plummeting. Modules make up about 65% of the hardware cost. My current favorite is the Canadian Solar 250mono, lots of power and great price.
ThatSolarGuy is offline   Reply With Quote
The Following User Says Thank You to ThatSolarGuy For This Useful Post:
Xringer (04-12-11)
Old 04-12-11, 08:07 AM   #12
"In your region 4-4.5 might be more accurate." I agree.
Plus, I have trees to the East that eat into the morning sun..
(and some to the west!)
But, if you don't care about payback someday, you can just say,
"Any free watts is good watts"..
Old 04-12-11, 09:32 AM   #13
gasstingy
All of the technicalities went right out the window for me the very first time I saw my utility meter spin backwards! I knew that this was a very good thing.
