Old 11-10-13, 10:02 AM   #1
Default Replacing old tubes with CFL floods
In the garage, I had two fluorescent tube fixtures, one over each car.
One of them has been buzzing, I got new tubes (40" or 40W?) and it still buzzed.
Anyways, I had some old security light parts left over and I have a bunch of left-over 65w CFL floods..
So, I recycled the parts and made a new fixture to replace the old Buzzer..
Two of those old 65w CFLs came out of the security light fixture for the back deck.
It now has some new $8.00 75w LEDs from Lowes.
http://ecorenovator.org/forum/sale-t...lood-%248.html
I used clear Krylon spray paint on these bulbs to make them more water-resistant..(I hope).
It rained last night, but not enough for a good test..
ID:	3618   Click image for larger version
Old 11-10-13, 11:52 AM   #2
how do you like the outdoor motion detector? The place I move into has one over the driveway door that doesn't work until you're on the porch. Thinking about replacing it before winter sets in.
Old 11-10-13, 07:14 PM   #3
You could have swapped out the old ballast with one of the new inverter types and actually get a better efficiency than CFL. The spiral design of the CFL means that it tends to block its own light. Try shining a flashlight through a CFL (turned off) and you'll understand the problem.
Old 11-10-13, 07:50 PM   #4
Take a look at the bottom of the unit. They normally have a time-out setting(with a test mode position),
and a sensitivity setting, which is a gain control that sets the detection range..
It might be set low, because it was triggering when cold(or warm) wind was starting to blow.
I have two that do that. Weather changes real fast in the late evening, lights come on for no reason.
Old 11-10-13, 08:06 PM   #5
Did not want to put any more money into the fixture.
I'm saving the tubes (I purchased last summer) for my two indoor work bench fixtures.
Plus, I had spare security light parts in the bin(Free) and about a dozen
brand new 65W CFL flood lights(Free) that will never be used, if I don't use them.
(I've been changing from CFLs to LEDs, so I have a LOT of spare CFLs).
Our garage is detached from the house, and my guesstimate is
those new garage lights will be used for less than 10 hours a year.
(Otherwise, I would install some new $8 75w LED floods out there).
Total cost $0.00 and, my wife is no longer bugging me about
the buzzing noise, and "Will it start a fire?" ete etc..
