Old 10-17-12, 01:23 AM   #21
ThomSjay
Good job on that!
TomS
Old 10-26-12, 12:33 PM   #22
bennelson
Home-Wrecker
Here's a couple photos of the finished project.
Might still get a little more paint, but otherwise it is finished an works well.
Old 10-26-12, 01:56 PM   #23
That has got to make life better.
I assume the little dark circle on the bottom of the top half is a latch for joining the two halves, stealth if so or is it just a knob?
Old 10-26-12, 02:08 PM   #24
bennelson
Home-Wrecker
The little dark knob on the bottom of the top half is one the OUTSIDE (hallway side) of the door.
It's a pull knob so that adults can pull the door shut from the outside when the bottom half is already closed.
On the INSIDE of the door is the latch that ties both halves together. I took a look at adding it to the outside of the door, but the latch was only designed to work one direction, and would have been difficult to reverse.
So far, at night, we leave the bottom half of the door completely closed. It locks from the outside, but that hasn't been a big deal, as she's not very good at turning door knobs yet anyways. We leave the top half unlatched, but closed most of the way. That can let in a little light from the hallway, and it's very quite and easy to peek in by opening the top a bit and looking.
Old 10-26-12, 02:13 PM   #25
bennelson
Home-Wrecker
Here's a photo of the latch that connects the two halves of the door.
When I remounted both door halves, I shimmed-up the top half to make sure I had alignment right on the latch before tightening everything down.
It works well.
On this photo the top half of the door still needs a second coat of paint.
baby-gate, dutch door
