Go Back   EcoRenovator > Forum News & Feedback
Old 11-10-10, 10:27 AM   #1
Default Forum restructuring
I have been thinking for a while to get rid of the projects & improvements forum. It does showcase the larger projects that get done. However, it also separates them out from similar discussion and topics. So, I'm thinking of moving all the threads to their respective forum (ex move AC Hackers heat pump manifesto to the geothermal forum) where it can reside with the other similar thread types. This should make searching for info (and posting in the correct forum) easier.
I'd love feedback on this or other forum changes you'd like to see. If I don't hear anything I'll just go ahead with it in a couple of days.
Old 11-10-10, 11:17 AM   #2
Good idea
Old 11-10-10, 12:20 PM   #3
gasstingy
I'm okay with that
Old 11-10-10, 01:58 PM   #4
TimJFowler
TimJFowler's Avatar
You could probably condense the number of forums even further than that. For instance, the four solar categories could be combined into two forums - Solar PV and Solar Heat.
FWIW,
Tim
Old 11-11-10, 10:13 AM   #5
Good point Tim. I think I will do that too.
Any other suggestions anyone?
Old 11-11-10, 04:08 PM   #6
strider3700
any possibility of getting the recent posts changed so that I can just hit reload on the page and get the new ones not an expired searchID message?
Other boards I'm on have a search_id=newposts for new posts here it's an ever changing number so the reload doesn't work after a little bit
Old 11-11-10, 06:57 PM   #7
Clev
Wannabe greenie
On both here and EM, I still get an "expired security token" when I try to mark all as read.
Clev is offline   Reply With Quote
Old 11-12-10, 07:33 AM   #8
Clev, when I use the link at the bottom of the main page it works fine. When I use the one in the 'quick links' menu I get your error. Does it work the same for you?
Old 11-12-10, 07:56 AM   #9
Unfortunately each recent search needs to create a new list as new posts are made, so I don't think this is possible. I'll look into it though.
Old 11-12-10, 09:00 AM   #10
Alright, the restructuring is pretty much complete. I made a few changes:
- combined the solar heat forums
- added a biofuels forum
- combined the renovations & new construction forums
- removed the projects & improvements forum and moved all the threads to their respective forum
I'm still open to additional suggestions, so shoot away.
Piwoslaw (11-15-10)
