09-13-18, 11:55 AM | #1 |
New Gree Sapphire? -22F
https://comfortup.com/products/gree-...s-12k-sapphire
I just saw the Sapphire units. -22F is the type of MS I'm looking for, to replace the old Sanyo in the den.. Anyone seen any user info on this 'new' line?
09-13-18, 01:05 PM | #2 |
http://17uo7e27w1attiybs22of10v.wpen...081318_Web.pdf
This link has all the info on this model. http://www.greecomfort.com/resources...ump_Revision_A That looks sweet. That is above their CROWN line it has a 2 stage compressor. The crown is two stage compressor also. That is two places above my TERRA SERIES. The crown is on the right. The crown puts out a little more heat but it uses more power to do it. I bet that would work great in your climate. They have it a little cheaper here. https://www.coolrunninghs.com/sap12hp230v1a.html Maybe you could find a coupon code to add on top of it. (I have never bought form this company)
The Following User Says Thank You to pinballlooking For This Useful Post: | Xringer (09-13-18) |
09-13-18, 08:28 PM | #3 |
After comparing the size, weight and power use of the 9k and 12k units,
I wonder if the difference is a firmware limit on motor speeds.?. For $100 more, I'll take the 12k unit..
09-14-18, 11:25 AM | #4 |
Jeff said before that a lot of times it is exactly what you said the exact same units just different firmware.
Between the 9K ant 12K units. They just run the 12K unit a litter harder and it uses just a little more power. ( I am ruffly quoting Jeff here this is now my core knowledge )
