Old 03-18-14, 02:31 PM   #1
Default Has anyone made their own Neutralizer for the condensate tankless heater makes
I was just draining this outside but in this cold winter it makes more than I thought it would. I was considering just making my own acid-neutralizing device. Similar to this one.
http://www.finehomebuilding.com/how-...iler-acid.aspx
Has anyone done this? do you have any suggestions?
Here is a well acidic water neutralizing filter
http://www.aces.edu/waterquality/faq...php3?rowid=337
Old 03-18-14, 03:00 PM   #2
Lowes has these do you think they would work?
American Countryside 0.5-cu ft Marble Chip
http://www.lowes.com/pd_2527-66882-2...ductId=3028435
I would make the container out maybe 2" PVC about 15" long. with screw on fitting at the top so I could refill it.
Or Home Depot on sale $2.50
http://www.homedepot.com/p/Vigoro-0-...0943/202292875
Vigoro 0.5 cu. ft. White Marble
ID:	4168   Click image for larger version
Old 03-18-14, 06:59 PM   #3
If it's PVC plumbing all the way, you don't need to worry. Otherwise, what you're suggesting should work nicely.
pinballlooking (03-18-14)
Old 03-18-14, 09:56 PM   #4
It is Pex but it just drains to the ground under my deck. I have two outdoor cats that would try and maybe drink that water. So I thought it might be good to neutralize it.
I am not sure if this would be bad for them or ever taste good to them.
Old 03-19-14, 02:17 AM   #5
Fornax
Like Mike said you don't have to worry about your plumbing in this case.
My tankless heater is connected to the rest of the wastewater via PVC-plumbing (no metal). You could throw a few pieces of marble on the spot where it drains under your house of course.
Also you don't need to worry about your cats, this water is not like battery-acid or something. It's more like mineralwater with sparkles. If it would be harmfull to your cats they would taste that and avoid drinking from it.
Old 03-19-14, 09:08 AM   #6
Since it is not going to hurt my plumbing you have the best idea just buying a bag marble and putting a nice pile at the discharge site under my deck. This is not a covered deck rain easily gets to this spot.
