Old 08-09-11, 08:35 AM   #11
My guess is lower RPMs likely means more current, which could lead to a hot motor..
I wonder if a current sensor could be used to control AC power input to a motor??
http://ecorenovator.org/forum/applia...r-limiter.html
Something like this circuit breaker, working at high speeds?
Once the motor got running it's max RPMs/load could limited by
the amount of current you allow it to draw..
RPMs would coast down between power cut-offs..?.
If a loaded motor normally uses 8A, but you limit it to 5A, it's bound to run a bit slower..?.
Old 08-09-11, 11:44 AM   #12
Induction motors are a different breed of cat than DC motors.
Here is an excellent explanation of how they work.
Understanding how induction motors actually work will help in giving useful advice.
Old 08-09-11, 01:21 PM   #13
Luckily, I wasn't giving advice, but asking questions.
Wondering if some missing 60hz cycles would cause the motor coast down a bit..
It seems like the motor would be trying to speed up and then slow down,
as the power disappeared, and then reappeared at the next Zero crossing..
To test the idea, I would need to build another control circuit, like this one.
But without the second SSR, since I would only be switching the hot side.
I would also change C1 to a much smaller value, for faster switching.
I'm wondering if the flywheel effect would come into play.?.
Maybe there is a low current setting that would allow my mill-drill to run
without the RPMs zooming up and down too much..?.
What do you think? Is it a waste of time to try it?
Old 08-11-11, 09:12 AM   #14
Maybe there is a low current setting that would allow my mill-drill to run without the RPMs zooming up and down too much..?
Is this a problem now?
Old 08-11-11, 12:26 PM   #15
I have been really busy on other things (getting ready for winter),
so building another power limiting rig is on a back-burner right now.
Once I get it built and tested, I'll know if it makes the RPMs surge,
and post my findings.
