Old 07-12-11, 07:36 AM   #1
Default Scavenging ambient electromagnetic energy
Interesting quick read. I'm surprised to see MIT working on this. Its been known for quite some time that you can collect small (quite small) amounts of power with antennas. Perhaps their wide band antenna can collect a sizable amount?
Scavenging ambient electromagnetic energy - Hack a Day
Old 07-12-11, 12:43 PM   #2
Piwoslaw
Piwoslaw's Avatar
Way cool! My neighbors are going to love me when I start sucking up the TV and wireless signals from the whole neighborhood
Seriously, would harnessing this energy be noticeable (weaker signal locally)? Or is it just energy which would be wasted anyway?
Old 07-12-11, 01:23 PM   #3
The antenna would basically block/absorb any signal that hits it I think.
Old 07-12-11, 02:07 PM   #4
One winter back around 1962, I lived on my grandfather's farm.
There was a barbed-wire next to the road, underneath the power lines.
I'm not sure how long the fence run was, but the top wire would zap you sometimes.
I always wanted to hook up to it and run a transistor radio.
But, all we had on the farm was a big old tube radio.
Because of the losses incurred using a small antenna and by distance,
Inverse Square Law
The amount of power you could harvest is pretty meager.
You might be able to run some very small devices.
People who live close to high powered transmitter sites,
might be able to power some small LED lamps etc, given enough antenna capture area.
Old 07-12-11, 04:31 PM   #5
Ditto that.
Seems to me that energy spent EcoRenovating will give a much better yield.
Old 07-12-11, 04:56 PM   #6
Thats exactly why I was surprised that MIT was even looking into the idea...
Old 07-12-11, 05:29 PM   #7
I didn't read the whole story, but my guess is, they want to power
some extremely small devices, that don't need much power.
But they need it over a long period of time.
The Russians planted many of their bugs with a LOT of batteries.
But, any bug that's self-powered is going to be long lasting..
The Russians installed large reflectors inside our consulate in Moscow,
then bounced hi-powered microwaves off them.
If someone was taking nearby, the soundwaves would modulate the reflector,
and the microwave return..
Old 07-12-11, 11:02 PM   #8
strider3700
If I key up my HF radio at anything over 50 watts my wifes touch sensitive night light will turn on as if it was touched. the antenna wire would probably be about 15' away from the light at it's closest point. the radio isn't powering the light but it is enough power to confuse the little touch sensor somehow.
Old 07-13-11, 10:14 AM   #9
Quest
done something similar back in my teen days:
While building crystal radio sets, we experiemented with a large spiderweb antenna and an air-gap condenser (standard 1-gang, 365pF) and handful of 1N60 rectifiers and a some electrolytic capacitors, I made a big tuned antenna trap to capture the loudest (contains the biggest signal from nearby AM broadcast) broadcast station, rectify it and use it as a DC power source to feed my little 1 (or was it 2) stage Germanium transistor gain stage for the second Xtal radio set up, so that I can use a speaker to listen to broadcast with amplification as opposed to a earpiece.
That was fun times... I still miss it.
Q.
(** Now, with solar cells so cheep, I'd rather concentrate my effort on cheep solar cell panels, cheep NiMH rechargeables to build stuff instead of doing something aforementioned...**smiles**)
Quest is offline   Reply With Quote
