Old 12-13-10, 08:45 PM   #11
If you want to go all out you can get gasketed boxes that have a flange around the outside with a foam seal.
problem that I see is getting the tape all the way around the box without it taking forever to seal each box.
Old 12-14-10, 06:12 AM   #12
Yeah, I see what you're both saying. I haven't gotten back to the project yet, but I'll post what I come up with.
Old 12-15-10, 10:14 AM   #13
bioplantcity
Default Try This?
Does anyone know the right way to use sheathing tape to seal around power outlets and light fixtures in a wall/ceiling? I'm working on the garage ceiling right now and am ready to start taping things up. A quick web search didn't find anything real useful.
Hey y'all,
First post!
I saw on a DIY program recently that they were using plastic sheathing and if this is a new installation you would install all your boxes, install wiring, insulate (walls) lay sheathing. Cut the sheathing and tape the sheathing into the box. Hang drywall finish, electrical trim and done. If this is not new sorry.
If this is an existing installation why not use low expanding foam?
bioplantcity is offline   Reply With Quote
Old 12-15-10, 10:29 AM   #14
Welcome to the site bioplantcity!
I'll be taping the sheathing to the electrical box. I just wasn't sure how its supposed to be done.
This is actually in a ceiling, so the insulation will be blown on top of the sheathing. I'll spray foam the rear of the box where the wires come through once the insulation is blown in.
Old 12-15-10, 10:34 AM   #15
bioplantcity
Cool
I wish knew of this site when I had built my house in '03. I am sitting here in FL in 40 deg outside and freezing inside.
sheathing, tape, tuck
