Old 09-25-19, 09:34 AM   #1
ferg75407
Default remove and replace solar for reroofing
My shingles are defective. Even under the solar panels, the shingles are deteriorated. The manufacturer is deciding how much is their responsibility. I'm retired and going to remove and replace the pv array with a little hired labor.
I want to use the same holes to mount the brackets supporting the rails. There are 5/16" studs screwed into the rafters as supports and I want to remove and reuse these. My dilemma is how to find the same holes through the shingles. I think marking the gutters as a close reference and draw a map of the mounts will get me close. I am considering putting a round headed screw in each hole before roofing then using a magnet to find the screws after the shingles are on. I shall smack the screws with a hammer, to define their location, then drill small hole and extract the screw. Then reinstall original stud and flashing and then replace the rails with hardware still mounted on it.
Military gps would probably not be accurate enough and I don't have it.
Any thoughts would be helpful, Thanks.
ferg75407 is offline   Reply With Quote
