11-01-09, 08:29 AM | #1 |
waste oil for heat, is it environmentally friendly?
I have a bunch of used car oil sitting around. I was going to offer it to the local guys to see if they could use it for heating. I am curious, is this a good use of it? I suppose it depends on the efficiency of the burner. Or, should I just go drop it off at a recycling center instead? I'm not really sure what the recycling center does with the oil.
Current project - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. & To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by Daox; 11-01-09 at 08:33 AM.. |
